coalminer16
I am working on my 60x72 polebarn still and would like to get others thoughts to economically block off a couple sections temporarily in the winter as needed to work on things. I have an open rafter design with spray foam closed cell insulation. I had them seal off two rafters to local two potential temp walls. I can seal the rest of the rafter off but I would like to be able to either lift and pivot the wall up out of the way or fold it to the side. Any economical ways of doing this? Last place had homemade bifold doors but didn't work the best and made of osb on the outside and I assume something more on the inside core. Doesn't have to be perfect but part of this is parking for 4 adults in the same building. I do have a 30x40 that will be heated all winter to at least above freezing but the other area I am hoping to have overflow project area for heating on my days off work only as needed if I am not working in the other shop area. Due to time, parts, money, ect sometimes I have a lot of project in different phases.
