threeputt
I got two ezgo golf cart engines that uses this design. I plan on removing the line and banjo fitting going to bottom block and use what they upgraded to later on except they didn't have this hole in the block. It goes directly in crankcase. The hose gets old and cracks plus the banjo will get loose and they leak. I was told I could remove this and put a 8mm x 1.25 x 12 mm setscrew in its place.
Not sure if they need to be stainless or will the one I showed work. I don't think oil would come through the threads.
I plan on using only number 25 and 26 in this picture and just use the two gaskets and two shorter bolts. Like I mentioned ezgo done away with this design because of leaks. They tried to eliminate oil getting into breather but it didn't work very well. Caused more problems as they aged as it helped.
It is an aluminum engine block also.
