Removing broken brass fitting
930dreamer
Amarillo,TX and Stinnett,TX
Hello, I'm trying to remove a broken brass fitting in an air conpressor tank. I sprayed penetrating oil on it two weeks ago and let it sit. It's about 3/8 in diameter, I'm worried I'll break the easy out . Won't budge, don't have a heating torch only butane for solder. 930
caper
cape breton
I've had good luck with using a hacksaw blade through the centre of the fitting to cut it into a couple pieces and remove it.Some minor cuts in the threaded bung of the tank will seal with the pipe thread dope on the new fitting.
travisd
Westminster, MD
Pick up some left-hand drills - it's possible that when you get close to the diameter of the brass insert that the left-hand rotation might just back it out.
idunnosh#t
central ia
You might have better luck with a pipe extractor than a regular easy out.I say might because in some situations ( brass) actually distorts when using any extractor and ends up tighter than it was.Probably better off drilling it.I've drilled a ton of em out like the other guys are saying.Hacksawed em and used a dremel or die grinder also.Goodluck!
srmofo
SW ohio
you can also pick up mapp gas for your propane torch, gets much hotter. Other than that I would just drill it
