67CarGuy
So the new house needed a storm door/screen door, and thus a new wood (mahogany) storm door was ordered. Cost a pretty penny, but looks great and should last quite a while. It came bare, so we primed and painted it, mortised out for the hinges, and went to hang it. Drilled three holes for the first hinge, screwed in the first of the brass screws that came with the hinge (the hinges that were provided by the door company), and watched as the screw promptly snapped off with about 1/4" left to go. OK, let's try this again. Predrilled for the second hinge, started a second screw *by hand* and didn't that one just snap off like the first one.
So now the door is back in the shop, and I'm trying to figure out how I can get these two broken screws out. My first thought was "I'll use the EZ-Outs!" which was well received by everyone until I realized that a #1 screw extractor appears to be the smallest they make, and not only is that just about the same size as the screw it's trying to remove, it really doesn't want to bite into the brass, it just keeps tearing it out. Maybe my method(s) are off...
The next idea (which has yet to be tried) is to take a plug cutter and drill out the wood around the screw, then glue in a dowel and pre-drill for a screw again. But before I go to that hassle, I wanted to check with the GJ brainiacs here and see if there's something I'm missing. Any and all advice will at least be read, if not followed!
