Rentals
lbgradwell
Oakville, ON
I very rarely rent a tool, but just this last week I needed to rent a pole chainsaw to take down an uncooperative tree. Not something I can justify owning...
speed bump
Butte Montana
Backhoes, Bobcats, big *** compressors (sprinkler line blow out sized ones), when I pull the welder out of my truck I might rent a skyhandler.
Little stuff: we rented a framing nailer once, a concrete saw a couple of times, and a big Rotohammer. I think we have also rented an aerator and a roto-tiller at some point.
Joe69
Muncie, Indiana
I own a small Bobcat(310). I don't rent anything. In the last 2 days, I have borrowed a Stihl concrete saw, a dumptruck, and a 420E Cat backhoe from my employer, though. I guess I'm one of the lucky ones.
Joe
fatfillup
Finksburg, Md
I have some folks rent pressure washers, both hot and cold from time to time, but that is part of my business. One piece that goes out quite often is a hot water heater the you couple past your cold water washer to make it a hot machine. Hot water goes after grease and also gum on sidewalks much better than cold.
I have rented scaffolding in the past.
boomerangg22
I rented a floor grinder not long ago to grind the floor of my garage so I could epoxy it. I have also rented a post hole digger (the kind that runs on gas, looks like a big ice auger) I'll tell ya it's a machine that kicked my a** LOL
61scout80
Crestwood, KY
i have not, but i have the local rental joint stuck in my memory. i would have no problem going there. on expensive items their prices are fair, but some stuff is just cheaper to buy....
http://appelsrental.com/equipment.php
I like to have my own stuff, even if it mostly sits. So if renting it more than once pays for the tool, or i could have good use for it i'll buy it.
if it is bulky i will rent it. I bought an engine hoist over 3 years ago, moved it 3 times and used it once. I should have rented that one....
supertooljunkie
Lilburn, GA
Had to rent a hammer drill the other day. Mine went out while putting a new electical service in my MIL's house. Bought a new one the next day.
Tile saw, rotary post hole digger.
chrislehr
Portland, OR
I rent about once a year.
Last year it was a tiller, then her Dad gave us his old one (which we left out in the rain and now I am fixing)
I needed a miter saw, got one, need a chainsaw next and may rent (i only have one other mature tree) and I will need a trencher (to dig for a small foundation to prevent bamboo from continuing to grow)
FastEddieG
Chicago suburbs, IL
Lawn stuff mainly. I organize a lawn aerator rental with my neighbors every year, sometimes 2x a year, so we all use it on the same day and split the cost. I've rented a dethatcher before, as well as a sod cutter. I also just rented a car dolly to get my Monte over to this new house over the summer.
I prefer to go to the local rental place first, but if they don't have the item, I'll goto Home Depot tool rental.
metal1313
clinton NJ
it depends on what im doing, ive rented a rototiler, and post hole digger this year. in the past i rented tools like a cut off saw, jack hammer, drywall hoist and a chipper. there are lots of tools i could use bnut really only need once. i do own alot of what i've rented in the oast though, i now own scaffolding, a mini tiller, and a cut off saw. im also looking for either a bobcat 310 size skidder or a dingo type machine
byrd
i work for an equipment rental company, i can definatly say that renting certain tools and equipment makes alot of sense. one great thing about working there is i get to borrow anything i want whenever i want!
Mickey O
Chicago, IL
Aside from trucks, I've rented engine hoists several times, sewer rodders a few times and a jack hammer.
alex71
SE Florida
machinery skates. I keep looking for some on craigslist, but so far haven't seen them cheap enough.
Shadowdog500
Down the shore
I rented a tractor with a front end loader and a backhoe for a weekend to pull stumps and spread a few truckloads of dirt.
It was so much fun that I joked that the rental place should have a big dirt pit outback to let people pay by the hour to just play on these things.
crewchief888
NW indiana
i work for a construction eq dealer, havent had to rent anything, but i do borrow a trailer a few times a year to haul my s-10 blazer.
i should buy a carhauler, but i'm a cheap SOB :bounce:
:beer:
