Repairing 7/8 plaster/drywall
jawmaw
We attached our new garage with a breezeway and to fit the breezeway we had to remove a window on the house.
House was built in 1957 and I have never seen this type of drywall before. It appears to be 3/8 drywall with 1/2 plaster for a total of 7/8. Has anyone ever repaired this before?
Photo attached.
Kamn
Ontario, Canada
treat it the same as a plaster wall.......we had this in the home as well before I gutted the place last spring and renovated the whole house
Daedalus
Button board most likely. In place of lath, gives the plaster something to hold onto. Drywall, tape and mud.
KenC
oklahoma
A couple of layers of 3/8 drywall with setting type compound between, tape and same compound over. Be sure to keep it a little low, then finish with more compound.
Diggla
Its called rock lath. Sheeteock with holes in it for strucco lite to adhear too. U can use reg sheeteock to fill then plaster to take out serious dips. Then compound
Cyberbear
California
Depending on your budget and amount of time and labor you wish to be involved with, perhaps you can cut strips of cheap 1/4" hardboard used as furring over the wall studs and cover that with 5/8" sheet rock to achieve the total thickness desired.
