Repirator advice
streetdaddy
Nashville,TN
Going to grind my floor and put on Nohrs polyspartic.
Do i need a respirator for either or both?
Can i wear a just a mask for grinding? Dont want all that junk in my lungs.
A fee years bad i inhaled a bunch of spray paint on a project and my lungs took a few months to recover.
38 Dodge Coupe
Delaware Ohio
Do you have a mask now that you use for painting? If so, since there will be particulates in the air when you prep the floor, why not just wear it?
S
streetdaddy
Nashville,TN
I have nothing currently. Didn't know if i need to rent something or can just pick up at depot off the shelf. Thanks
gregtwojeeps
Ky
Get what 38 dodge says, and don't cheap out and use the white paper masks as they just will not seal to the face like the 3M will. Grinding concrete, even with a shop vac hooked up, will be heavy in dust . Dust that will not come back out of your wet lung air sacs. ...
Yes, they are a more expensive mask, but it has replaceable cartridges and can be used for many years for painting or high dust environments. You only have two lungs and having a damaged one is no fun. I know, I had a major PE in 2013 in my right side lung due to a large blood clot . . JMO
rlitman
Long Island
A P100, or N100 or N95 mask will oniy stop particulates. That includes dust, and to a lesser extent mist. Vapors are stopped by a mask with an organic vapor cartridge (visibly much bigger and contains activated carbon).
LegacyIndustrial
deerfield, IL
Coating: NIOSH RESPIRATOR, same as you would use for spray painting a car.
Use in conjunction with ventilation (open door/windows).
Grinding concrete: A good 3m dust mask
Garage Flooring
Grand Junction, CO
We have NOISH approved respirators available for 19.95. If you need one just PM me. They are made by 3m and come in small, medium and large. I am 5-11 175 and I go medium.
altersaddle
Victoria, BC
I wear a North half mask with a backpack adapter. Just got new filters that will handle organic vapors, acids, fertilizers, etc, and have the P100 filter for particulates. The backpack puts the filters over my shoulders so I can use them with my welding mask or face shield.
I like that the North system is very flexible, I can remove the backpack adapter and just use dust filters if I want to do a lot of woodworking and don't want the extra bulk. I think it can also be upgraded to a contained system if I ever needed that.
Don't skimp on safety equipment.
bp460
Chicagoland
I prefer North brand respirators as well... lightweight and very comfortable. I believe they have a cartridge that will handle both gas/vapors as well as particulates.
-Brad
