Replace bit portion of bit socket?
Chipm
Georgia
Hey guys,
Are the bit portions of bit-sockets (like, a 1/4" drive bit attached to a socket) just press fit? I have a broken T27 that is part of a set that is sentimental to me, and replacements are NLA. The bit itself seems to be a typical 1" long 1/4" drive Torx bit. Can I just press it out and press a new one in? Or are they epoxied/soldered/otherwise attached?
Thanks,
Chip
theluke
central pa
I broke a Gearwrench torx bit. Pounded it out with a punch then pressed a new torx bit in with a vise. Quick and easy.
Skin
Boston
Its either press fit or held in place with a set screw.
You can buy replacement bits from SK assuming its USA and you want to keep it that way.
C
Chipm
Georgia
Thanks! Knocked it out with a punch and tapped a new one in. Good as new!
B_Bimmer
Eastern Iowa
I intentionally buy smaller bit sockets that are 1/4" hex for just that reason. Bits are cheap and always faster then going anywhere for warranty.
