Replace Casters on Older Snap On Rollaway?
hobby_guy
Working in the garage
I have an older KR655 with I believe the original casters. There is a side box and now a top box installed, so the whole assembly is probably fairly heavy. The original casters are 5" x 2" 300 lb rubber over iron and are still available from S-O. They said a 600 lb 6" x 2" medium duty monoprene (soft) is available. I took a look at the current single bank roll-away S-O sells, the KRL756 and it uses a 900 lb rated GLA-polymer caster.
So, what do you think - do nothing (keep the old casters on there), replace the casters with the same p/n, install the 'soft' 600 lb rated ones or install the 900 lb heavy duty ones? (Note that the 900 lb ones are like $100 each, the others like $40 each.)
JUNK-MAN
PA
I have the same box, casters should be covered under warrenty. If you dont move it a lot though, i wouldnt worry about it. I qould just clean up the ones on it and grease thwm and that should be fine for the occasinal move.
Sgtboz
Here's a tip: Your Snap On dealer should warranty damaged or worn out casters and drawer slides. I realize this doesn't really apply to your situation but something to keep in mind
