Replacement 5/16 shank tips for impact screwdriver?
atxjax
Been looking around the web and I have yet to find a good source for replacement bits for my impact screwdriver. Broke my last bit trying to get off some rotor screws on a Honda Pilot.
Bits I need are 5/15 shanks # 2 and #3's. Anyone have a good place where i can buy?
WildwoodChuck
Peru Indiana
VIM from Amazon.com they have a set for 8 dollars it's nice, Toptul has larger T60, T70 Torx. Napa has them in store for less than 2 dollars.
6PTsocket
Trying to remove rotor screws from the Asian vehicles that use them should be a separate thread. The bit breaking is almost not much of a surprise. Some people have luck striking them first. The last ones I took out had all the rust under the heads of rhe screws . The threads were not rusty at all. Usually, after a quick attempt to unscrew them, I just drill them out. As many threads will agree, they are not needed and just keep the rotors in place as the car goes down the production line. Sorry I am no help on good bits.
Sticky Grips
I twisted mine getting the phillip's head screws off of my civic. I bought a replacement a replacement Lyle unit at Sears Hardware of all places.
TNBurban
Go to HD and get whatever Milwaukee impact shockwave set fits your needs. Has not let me down yet.
ecotec
Why do they not use anti-seize on these screws?
If buying a Honda, it would be worth pulling these screws during the first tire rotation to put anti-seize on them.
WWheeler
Middleofnowhere USA
No doubt. Or just take the screws out and leave them out. There's no real need for them but they can make slipping the calipers on/off a little easier since that's all they are there for I gather. If the screws fight you too bad you can always just drill them out.
While you are at it a light coat of anti-seize on the back of the rotor is also a good idea. I always do and they come off easy-peazy next time.
markhm
NY
Agree with comments about Honda and Acura. Have never found ones that wanted to be removed. Always had to drill them out.
shockwave
Marietta,ga
Might look into koken since these screws on Honda are jis and in between ph2 and ph3
Stay away from lisle impact driver and bits
Look at matco I believe Porto unit or snap on work best for me with atleast 32oz hammer I usually go for 4ibs sledge
I have seen too many twist off without using the right hammer with these screws and only Gand tighten back they will not go anywhere
To the op I use a stubby ph3 from snap on or matco apex bits
But wiha and zephyr come to mind for the money vim would be good too
6PTsocket
+1
Greg85mcss
Frederick MD
I had a snap on guy that sold lisle and would warranty them but I have never broken one myself. Seems like any time I loan them out they break though. Pretty sure lisle & craftsman are the same. Only difference I could see is on the driver itself one is 1/2 drive and the other is 3/8. Bits have the exact same markings.
WildwoodChuck
Peru Indiana
I just had this printed Thursday night to store my bits. I have mixed brands, T45 and bigger I don't brake much.
californiaHank
Vessel makes good ones (and good hand-impact screwdrivers to go with them). Their cross head bits are all JIS - especially good for fasteners on Japanese cars and bikes. They're often listed by on-line sellers as 8 mm rather than 5/16", but they're the same size.
