Hoopy Frood
Finally, my first post in the vintage tool forum! I've always wanted to post in here, but have not had time for "leisure" forum activities. Fate has forced my hand... to what end? We shall see...
My drill was in the process of dying so I decided to look for a vintage replacement at my favorite used tool place. I found a very odd unit. I believe it to be a 1950s model from Black & Decker. There's not much info out there on this "U-500 Power Driver":
http://powertoolstudy.blogspot.com/2011/06/black-and-decker-u-500-drill.html
It's an amazing little drill really. It ran in the store and sounded tip-top, so I took it home. Unfortunately I didn't think to check the chuck at the time and now that I've actually tried to use it the chuck is pretty much trashed. I tried for a couple hours to get it apart. I'm not sure if you're supposed to use something like a bearing press to remove the sleeve. Even if I get it apart I'm not sure it will be repairable - you REALLY have to force the sleeve with the chuck key to get it to move at all. Generous use of PB Blaster certainly helped, but the chuck needs real work.
The chuck is a vintage Jacobs "Multi-Craft" 1/4" Chuck:
http://www.jacobschuck.com/jacobs-30243d-1-4-multi-craft-drill-chuck.html
As far as I can tell this is a light duty chuck that is not meant to be rebuilt like some of Jacobs better chucks. So I thought "No problem, I'll just replace it with a new chuck."
The problem is this chuck appears to be mounted on a stud. It's very common for chucks to be threaded with 3/8-24 (or whatever size) female threads to go onto a threaded spindle that's the drill's output shaft.
But this little chuck seems to have 3/8-24 MALE threads... the "spindle" in the drill is recessed 3/8-24 female threads in the center of the final drive gear. Some pics are attached below to clarify...
Even the current Jacobs "Multi-Craft" chuck has the female threads that are so common.
I will write to Jacobs about this to see if they can help. Any info I get I'll post to this thread...
But I'm quite new to drill repairs. I know chucks can be mounted to other kinds of attachments, but I'm not familiar with them. Is there something I'm ignorant of that could make replacing this chuck easier?
It seems like I could just get some 3/8-24 threaded rod and make basically a ****** that could attach a new chuck to the drill. Is that a lame idea?
I really do want to make this work because this drill is in REALLY nice shape. I've been over it top to bottom. Purrs like a kitten, surprisingly nice ergonomics, built like a tank... I'd hate for a lousy chuck to torpedo an otherwise great tool.
Fingers crossed!
Fingers crossed!
