Repurposing old pots and pans.
Joelk
Bedford PA
I almost never throw anything away so I have a fair selection of old pots and pans.
Aside from dog dishes, what do people use them for?
L5wolvesf
Northern AZ
I have an old Wok I use to soak/clean off parts in. And stir fry brake parts don't taste as bad as they might sound - with lots of soy sauce.
BDT/NWMN
Erskine, Mn
Stainless steel mixing bowl is used to soak transmission parts in ATF.. Cookie sheets are used to keep parts in order. Kitchen strainer is used in parts washer when cleaning small parts. Pots or roaster are used with oil for heating parts.
rlitman
Long Island
I've got a few pots retired from the kitchen to use as catch pans.
Old non-stick cookie sheets are used for mixing epoxy on.
MikeF2316
Thornhill, ON
I use them for storing larger pieces of hardware, brackets etc. As noted they're also good for soaking things of the appropriate size for cleaning or lubricating etc.
Parrothead
Earth
I donate them, but the pots and pans I have now will be with me till I'm dead. I was like a lot of people who bought the low to medium priced stuff and replaced it when it warped, handles broke/cracked, etc. I bought some good stuff about 8 years ago per the recommendation of a good cook, and wow what a difference. The heat distribution and ability to control it is WAY better. Much like our tools, spend the $300 to $600 and be done forever.
Something like this (not what I have)
https://m.bedbathandbeyond.com/m/pr...egoryId=12063+4294966331+510110073+4294967041
southalabama
Brewton AL
Boiling cosmoline off gun parts and mags.
Note. Never let your wife catch you with a pot of boiling water and cosmoline bubbling up on her stove.
dodge610
North Canton Ohio
I collect them then take a good sized load to scrap for money. Then that money is put in my tool fund I get them all the time on my trash route last load had about 50 pans in it.
joe--h
Long ago & far away a pot of used oil and the fiber timing gear for a 50's Chevy 6 cyl.
Put it on low and went outside. What a f-ing stench that was. Unhappy wife too, go figure.
Joe H
I have found that nothing cleans lawnmower wheels like dishwasher. They come out like brand new if you spray them with Simple Green or "purple stuff" and take a brush to the tires first to get the mold off.
I just dump about a half a cup of Trisodium Phosphate and some bleach into the dishwasher and run it through a cycle empty when I'm done.
No problem!
mbshop
visalia ca
Making wax slugs. Parts cleaning. Storing parts. Ticking neighbors barking dog off. Plus previous mentioned uses.
tvtaurus
Indiana
No problem!
Do you have a separate dishwasher, or do you do this while the wife is out?
Bondo
Greenfield, Maine
Ayuh,.... My ole lady, 'n her sisters are into house plants,...
I've built many flower pots outa lotsa different junk,....
Cookin' pots is but 1 of many,...
Here's an old prop, turned into a plant pot,...
Not the easiest to see, but a mobile usin' 6 propeller plant pots,...
I've made several other cookin' pot/ plant pots, but ain't got pictures of 'em,....
gdocktor3
Connecticut
Melt lead for making your own musket balls or send them to Tony Beets or Parker for heating their gold cleanups. Todd won't be needing any...
tvtaurus
Indiana
Of course Todd won't be needing any. He is a Joke. Might as well quit and become a sanitation engineer.
Wood'nMetal
PNW Oregon
I use muffin tins for holding small parts on big projects. Pie pans get used to catch oil drips when changing seals, etc.
BDT/NWMN
Erskine, Mn
I needed to come up with a large seal driver and used a heavy duty aluminum pot that was a perfect fit.
bsg1
so cal
with some old cookware, it's best to know what you've got before repurposing it to tasks in the garden. desirable examples of certain brand OldSchool cast iron pots and such (Griswold/Wagner/others) have collectible value, and examples of pieces that are not so difficult to find can have collectible value as well. some variants have value where 'the sky's the limit' while with others the limit is the sky. a good online reference site is the Wagner & Griswold Society (WAGS) which is an online community of cast iron and aluminum cookware collectors that includes an active forum.
