A down spout had been draining at the base of my house for (I assume) the life of the house (built in '77). This caused water to erode some of the foundation and find its way into my house. Last year I dug the foundation up to fix the leak. Now I want to fix the source of the problem which is the down spout.
This is how it is right now:
I'd like to divert all the water from my down spout to the base of the hill along the fence line. I've heard varying opinions on how to go about doing this but this is what I was thinking.
I'd like to put the down spout straight into a 4" PVC pipe and run it down to the base of the hill. I'd also like to add a wye near the top and add a catch basin there as well to catch any run off from my neighbours property/downspout. I have a few problems, questions and concerns though:
1. I can't find catch basins where I live (tried home depot, lowes, rona, home hardware, plumbing stores etc.). The ones that do have them are outrageously priced.
2. I was told that putting the down spout into a 90* like that is bad as the force of the water (it's a 2 story house) will erode the fitting such that water will end up dumping right next to my foundation.
3. I'm worried that placing a catch basin or anything near my foundation is a bad idea as it's just another place for water to collect, yet I'd still like to route surface water away from my foundation.
4. I wanted to run the pipe into a pit of some sort at the bottom of the hill. Is it pointless to do that? The area gets really wet, especially in the spring, so I'm wondering if it would be of any benefit.
5. I want access to both the top and bottom to be able to check for blockage.
6. I want to avoid water sitting anywhere in the pipe and freezing, since I don't plan to bury it below the frost line.
Alternatively, I could just run the down spout into a PVC pipe, forget any basins, and run the pipe open to the surface at the foot of the hill. I'd have access to both ends and water shouldn't freeze in the pipe. The only problem is then I wouldn't solve the problem of water sitting at the foot of my foundation.
Thoughts? Any help is greatly appreciated. I'm stressing out over this as I plan to do it Friday when I tamp everywhere I backfilled last year and get to reseeding.
