HOTFR8
Now the B & B idea appeals.
LOL... In this Case you will have to go to the end of a very long line just to have your Adoption Papers looked at...
Yes, Tom will have to start his own version of Boys Town if he's going to adopt all of us.
Hey Tom, Considered any FREE labour out of all these wanna be adopteds.
They say "many hands make light work", but in this household, it seems that many hands make more projects (and, thus, more work). So I don't think adoption is a great idea from our end. In your mind, it may seem like a good deal for you, but, trust me, you have no idea what you'd be signing up for. If you've gotten tired just watching what's going on here on GJ, you don't know the half of it. Glad you're all having fun, though, because we certainly are!
Chris
(And HOTFR8 - it would ALL be free labour, but we do provide meals!)
I was just thinking of that after I posted. You would be busy Chris.
Not to mention sleeping quarters and showers Chris.Are you fixing to start a GJ army to get everything done?
Chris, are we going to have company when I get home?!
Thomas
Boy, I leave the country for a couple of days and when I get back I find you guys get into alllllll kinds of mischief!
Thomas
I hope no one is planning to pop in (I know you guys would at least have the courtesy to PM first, right?) because the guest rooms aren't ready, I don't have any food in the house and I'm too busy working on that all-important test! (and neglecting a couple framing jobs along with some other things)
Chris
MisteR Tee I didn't know that so many thanks for passing it on, yes I glad to know. I'd have never guessed that's what they'd call it though, who would have thought.I'm guessing they start racing around May or so?
Thomas
Sorry about the "echo", my PC was playing up & just wouldn't load my reply up, so I foolishly clicked it again! Don't ya just hate it when that happens??![]()
Did someone say open adoption day? I'm in..lol
Thomas and Chris, AKA mom and pops..![]()
I said open day
Open Day, B&B, Drag strip?!! Count me in!!!!
Forget the test Chris!!
Must be the -op- that is common to adoption and open, though one is a short 'o' and the other a long 'o'. Understandable to a special ed teacher (me), but .... well, I think it's a case of all you anxiety-ridden future test takers. But, no one ever said the test was required - only if you want credit and a prize (and recognition and a feeling of pride once you get through it). Or you could take the test and not turn it in. Hmmmm...
Back on the job,
Chris
PS, I just noticed were on page "327" a very familiar number, isn't it?
Thomas...
PS, I just noticed were on page "327" a very familiar number, isn't it? Dennis![]()
... and this post number is the cubic capacity of a Bristol Bus
Working most of today outside (109F - 42C heat index, hot. hot, hot!!) When I got home later I looked like something the cat had drug in.We're finishing up most of the last of the hedge row clean up. It is looking fine and it's really opening up the view from the shop. No pain, no gain!
I did want to get this on here so, continuing with Project OPC, Part II.
With the base now powder coated, the casters were bolted on.
The casters selected were Blickle, made in Germany. Any followers here from Germany? You guys make super fine casters! These are sealed ball bearings, so no grit from the saw will get into them, non-marking rubber. They're about 5" (125 mm) in diameter, with about 500 lbs (225 kg) weight capacity.
Two of them have foot activated brakes (easy on-easy off) installed in opposite corners to keep the saw from swinging around when in use.
With the base turned over, the ends of the bolts needed to be finished off.
What goes well with powder coat? The obvious solution to that is polished stainless steel nuts and washers of course!And in this case, stainless steel acorn nuts which will also act as lock nuts on the bolts.
As I'm sure you know, washers have two sides to them and one of those sides is always a finished side with rounded edges. That's the side that goes up and will be seen.
To prevent galling with stainless we should always use a dab as opposed to a blob of anti-seize on the threads.
The acorn nuts are then installed. On the inside bolt a regular nut was used since it's hidden inside the base of the saw and unseen. All the hardware is grade 8.
So the base is all ready for the saw. Because the saw weighs several hundred pounds, moving it onto the base by myself took some thought and a little effort.
If you're fortunate enough to have a John Deere (or any tractor with a bucket for that matter) this isn't so difficult.
Some ratchet straps...
...around the saw and attached to the bucket and...
...it was placed on its new base with nary a mark or scratch to that nice powder coating. Actually I just used the bucket and loader as a stationary frame that the saw was suspended from. The tractor wasn't even running during the move. I used the ratchet straps to slowly lift the saw up. That allowed me to creep it up and still have a hand on the saw to steady it. With two people I'd probably use the tractor hydraulics to lift it, but by myself I thought it best to be right with the saw since I wasn't sure about its balance point. Once it was over the new base, I did let the bucket down, which you can do without the tractor running; gravity takes charge.
It rolls effortlessly on the new base and the large, wide casters don't dent up the tile floor.
The orange powder coat is almost an exact match for the factory trim.
Because the factory base tapers...
...there is some side clearance on the new base.
Overall though I think it's fine.
It adds some "Bling" perhaps to the fab room. I think it would have Mr. Johnson's approval, seen parked between his floor press and cast iron bench.
That project is now done and I have a couple more projects in progress that I'm presently working on. I'm starting to formalize my thoughts on the next big shop project, a "Portable Dirty Room" or PDR. Check back to see that one take shape.
BTW Joe, I am still working on the tool shed from time to time. I haven't forgotten!
Hot, Sweaty, Sore and Tired Thomas
We don't have "old" people around our place. We have 'Living History". They're the ones to have around when you really want to know what a piece of equipment or trim is. Actually, they're "Living Encyclopedia's" and they're so willing to share their knowledge which is irreplaceable. They've got 30 years on us and we'll never catch up!
Chris
I'm sure she meant well and all, but geeze, makes you sound positively, well.........old!
Youthful Thomas (don't let the gray hair fool you)
.Hello,
My name is Stan, I am from Germany and my english is not so good. but google helpsI can understand a lot, but do not write well.
Adrian showed your beautiful workshop:
http://adrian.kochs-online.net/2012/12/05/johnsons-welding-and-repairs/
Since December, I have read all the pages.
now I have a few questions:
where is the thermal insulation of Mortonbuilding?
why only old people come into your garage?
I built a small garage:
But the next garage I build as your Johnson's Welding and Repairsthis is the best workshop I have ever seen ...
finally I have something for you:
a MTD tractor for snow shoveling
he would no longer drive, the belts was old
but now he is back
Stan
Hello there Stan and many thanks for your kind words and posting your pictures. Nice job on the garage, making the most of what space you have.Did you recycle the bricks from the wall you tore down and use them in the new wall? Also congratulations on bringing the MTD tractor back to life. Makes you feel great doesn't it and you've had a lot of snow to shovel with it this year.
To answer your questions on the thermal insulation in the Morton building. The floor has...
...styrofoam under the concrete, the interior used Morton's "Energy Performer Package":
http://www.mortonbuildings.com/Energy_Performer_Insulation_System.aspx
with 6" (15.24 cm) thick, uncompressed fiberglass wall blankets rated at R-19 that span the walls from post to post with no seams in the blankets creating continuous, uninterrupted wall insulation. In addition to that...
... I had the building wrapped in Tyvek as a wind break to cut down on wind infiltration.
Both of the overhead garage doors...
...use injected urethane foam for R-19 insulation.
In the attic space overhead, there is blown in, chopped fiberglass 18" (45.72 cm) thick with an approximate R-40 value. The building is extremely economical to heat, even with 16' (4.87 m) high ceilings and stays cool inside during the warm summer months.
Thanks again Stan for posting in and I sure do like Blickle casters. Sehr gut!
Oh and one thing more Stan. I see from your avatar you have an assistant in the garage like me only my assistant has gray hair and whiskers and yours..............well your doesn't.
Thomas
Really great thread, it is cool to see all the stuff you have found in there. As well as the cool cars.
@thomas, in addition to the cool 327 pics: did you know the chevy 327 was also used on this side of the ocean?...
opel diplomat 5.4 (I just love those cars)
The grey hair fools no one as we all know that has come from all those wanna be adoptees you have stressing you out..........
Hey Thomas, didn't they give you the title of SENIOR pilot; oh wait, maybe it's SENOR pilot since you spend a lot of time in South America. (heh-heh)
Another thought.... with over two million visitors to this thread, it might qualify Thomas as 'Living History' already; so many people learning so much by just 'Inter-visiting' with the 'Old Man' at his virtual shop! lol
(I still think they sent us an extra purple wire and gee whiz, I didn't think I'd have to modify those plugs to get them to fit and what's that spare hangy down thing for anyway? Sheesh!)
