I scored a sweet 8' long work bench top from a retired steel worker. He had it left over from his shop build, but it was stored outside and has a good amount of rust on it.
Whats the best way to tackle the rust and coat it ? I was originally going to hit it with a grinder and then start sanding it out with a DA. I grabbed some 140 by hand and gave it a good rub to see what kind of bite the rust had, and it came off real easy without any hard pitting. So now I am thinking of starting with 140 and moving up from there.
Phosphoric acid was recommended to remove the rust, but other than rust-mort in the body shop, I have no experience with it. Bit leary of using chemicals at home too.
Also, what would you rub the top down with to keep surface rust from re forming ? He said he just rubs his down with a slightly oily rag now and again and it does the trick. His benches looked perfect.
Any hints, tips, ideas welcome.
