Marvelicious
I picked this baby up off Cragslist for about it's value in scrap metal, but I'm fairly confident that it's worth saving. Based on the casting number on the head, it is either a Wilton or Dayton (was sold as both). Wilton/Jet still sells essentially the same model (J-A5816) with a few updates. As near as I've been able to find, most of the part numbers interchange.
Here it is as I bought it:
...and after just a bit of elbow grease:
Obviously the cleanup will continue, but it was nice to find something under the grime. There is virtually no slop in the quill and a dial indicator running on the outside of the chuck is showing less than 5 thousandths runout.
If the rear pulley was still with the unit, I'd just replace the motor, but that part alone is at least $200, plus the motor and I'm not entirely sure I want to listen to the variable speed belts. For similar money, it seems likely that I could replace both pulleys with simple stepped pulleys, and pick up a 3 phase motor and VFD instead of the single.
Anyone have any input? Yay or nay? I'm not opposed to spending some money, as I think the end result will be worth it...
Also, I'm not 100% how the chuck/arbor/spindle all goes together on this unit. A blurry old copy of the original manual states that assembly/dis-assembly should be "self explanatory" based on the exploded diagram. Well, maybe if it weren't a pdf of a photocopy of a manual that is older than I am, but it isn't all that clear to me. I'm inclined to pick up a set of drill chuck wedges, but I want to be sure that it doesn't have some other means of attachment before I start trying to beat it apart! Anyone have any insight?
