Retractable Air Hose Reel Installation Help Needed
victor07
A couple of weeks back I found a posting that detailed how to install a retractable air hose reel on your garage ceiling.
I can't seem to find it. Can some one tell me the best way to install it?
It seems heavy and I want to make sure that it dosen't fall down on my truck.
thanks again for all of the help,
akdiesel
Wasilla, AK
I have not seen this thread, but the easiest way would be to get two u-bolts that span the distance of the mounting holes on the hose reel.
Get a templet from the mounting pad on the hose reel and mark you holes on the ceiling after you find the center of the truss stud. The u-bolts also need to be long enough to stradle the lower section of the trusses and also penetrate the sheetrock. tack down the u-bolts to the trusses with some large staples to keep them from moving on you when you secure the hose reel from below. Use lock nuts also.
logical
Northern fringe of the Motor City Suburbs
I don't like any design that uses lag bolts up into a joist or sandwich of wood studs/plywood/etc. If the wood rots or even goes through humidity change cycles, the lags could loosen and you'd never know it until the reel comes down on your head.
The U-bolt over the joist sounds much more "right way" to me. When I hung my heater, I laid a 2x6 flat across the top of several joists and bolted down through it to the heater. For my reel, I did the same thing but also nailed in a brace between the studs and against the drywall to stabilize it since my joists are 2x8. I had to use 10 inch bolts i think.
