Rewiring the kitchen
Chuckster in NJ
Hunterdon County NJ
One should be to the left of the sink and one to the right of the sink.
There is no requirement to use GFCI breakers. You can use GFCI outlets instead. You can have more than one countertop outlet on each circuit as long as they are AFTER the GFCI outlet/breaker and on the same side of the counter top as the GFCI protected outlet.
I am pretty certain those circuits are not allowed to power anything else.
Ground position on countertop GFI receptacles up or down?
Nooooooooooo, You're making up stuff. As long as there are 2 sabc gfci protected in some manner feeding the countertop recepts, they can be in any order.
First, understand the difference between "should" and "must" !
What I was saying is "best practice", not code.
Chuckster in NJ
Hunterdon County NJ
The NEC does not say “should or must"………. "SHALL" is the word.
BTW! "What if" is another common word used in code arguments……… And "what if" is not in any of the codes.
dave*99
Coastal NJ
NO!! The way you appended your answer onto the prior statement indicates otherwise.
Reads as much more definitive than "could", even easily interpreted as "should/shall" or must.
Do you consider this best practice?
"One should be to the left of the sink and one to the right of the sink."
dscheidt
Horizontal. Ground pin to the right. Unless it's to the left of the sink.
Ground left is usual around here (Chicago, home of the horizontal outlet), at least among electricians who pay attention. (I see lots of spaces where there's a couple outlets mounted the opposite way from the rest o them. I have so far resisted the urge to fix them.)
sparky 1971
Central Iowa
Ground left? What if it's to the right of the sink?
gahrajmahal
Cincinnati, Ohio
I suggest the OP go to the Central Iowa permit office where he or his contractor will be requesting the electrical permit. They should tell him what they require for him to pass code.
During my sons two year fiasco building a 16ft addition to the rear of his house, I met with the inspector several times (since the general contractor or one of three electricians that worked on it couldn’t be bothered to be there). The inspector was very sympathetic and let us know how to fix all of their mistakes, pull the correct gauge wire, add GFCI’s, put nailers on the studs, install the correct breakers etc.
Many towns have good websites showing and describing how to correctly wire a room, bathroom, kitchen, garage etc. As a good reference I like the Home Depot 123 books.
sparky 1971
Central Iowa
Everybody wins.....1760654384288.jpegor 3 losers and nobody is sure who won.
That says hospital grade. This thread is about kitchen wiring. If someone were to cover the green dot and the lettering and try to use it in a house would it still have to have GFCI or AFCI protection?
mm08822
.........Ahhhhhh, that was a joke for solving the direction of ground. Since everyone had a direction: N, S, E, W, this was the peacemaker! I used the first pic found. HG and surge suppression was insignificant for my purpose. It would need the required protection specified based on location. Can't say I would want one of these in my home.
Here's a plain jane version........
dscheidt
I have seen those in hospital rooms and high end office cubicle units. They solve the wall wort interference problem.
Norcal
That quad receptacle still would need to be tamper resistant, can't have the little darlings sticking objects into the receptacles.
dscheidt
Hell no. Best practice is to provide receptacles powered so they don't trip breakers. If you have some idea how the kitchen is going to be used, you can distribute them appropriately. That might be "one circuit left side, the other right"; however, it might also be "this outlet on A, that one on B, rest doesn't matter" where you know that two high load appliances are going to get used at the same time. In the absence of specific use, interleaving them is better, but since that usually requires more wire it's not done that often.
The wrong way to do it is to put the GFCIs for both circuits in a two gang box, and then only use one circuit for the rest of the outlets. I lived in an apartment where it was done that way. The whole complex was like that, according to the property manager, who got lots of complaints about it.
dave*99
Coastal NJ
Agreed, I have usually found interleaving to make good sense. In Kitchens and workshops too. I think meeting or exceeding code and applying some thought to the layout and usage are the best practice.
