Reznor UDAP 45 Exhaust Vent Options
ED26
MI
Looking at different options to run the B Vent vertical through the roof; with mounting the unit in the corner of garage. The picture below helps explain my two options.
Option 1 - run the exhaust directly through the roof where the unit will be mounted in corner of garage. From gutter probably 5'. Will this be an issue with potential snow drifts on roof being in Michigan
Option 2 - run the exhaust up, and then on an angle riding the roof slop, then exhaust towards the top of the roof. This option requires more pipe and not sure if affects exhaust performance with the angles of the run.
E
ED26
MI
Option 3 horizontal side wall vent........beats 1 and 2 when feasible.
Horizontal not option. Have around 2’ soffit. The pipe need to extend past that. Would look like **** I think
Showkey
"MEMBER EMERITUS"
Wausau WI
Front, side or back of the building would make a huge difference on all options as far looks ?
2’ in 10’ rule is not going to good look if end up with 4’ stack in some situations :dunno::dunno::dunno:
E
ED26
MI
Exhaust is on rear slope of garage.
I asked a local contractor (reputable) and did not mention it needed to exhaust above the ridge vent...
Ran that by another contractor and said same thing.
Trapps
The Detroit Zoo
Check local code for stack height to roof and peak dimensions; the cost to trust but verify is cheap.
For the 'plumbing,' I'm always a fan of KISS. Option 1.
Best,
Mark
E
ED26
MI
Best,
Mark
See your in Michigan - any help on the local codes you can help me with?
E
ED26
MI
Found this image online, can someone give me an example, my roof is 5/12
E
ED26
MI
It's power vented 2 ft. above 10 ft. away don't apply. horizontal out gable end is best.
Thats what i was told by local licensed professional. And also from other folks in HVAC...so i guess i just need it to be a 'certain height' from shinges. Pitch is 5/12 so nothing major. No walls on either side of garage. No valleys, etc. Basic roof, no dormers, no rev gable etc.
How far above shingles ?
brewchief
Needs to be minimum 12". I prefer a high wind style cap in a situation like this.
Sent from my SM-T510 using Tapatalk
2Convertibles
Pittsburgh, PA
I have 2 Reznor units, one each in 2 car garages. I love them! Quiet and does the job. We vented out the side of one and the back wall of the other. At first I thought it would look stupid... a big exhaust with a big round vented end that is almost the size of a basketball! It looked fine. Really professional. I don't even notice it any more, and one of them is on the driveway side. Just my 2 cents. Hope it helps the decision. I can post a couple pictures if you'd like.
E
ED26
MI
Which model do you have? I’d like to see some pics and a video running if possible to see how quiet
2Convertibles
Pittsburgh, PA
Let me know if you can see the pictures. I took a video, but can't seem to get it to link here. The sound of the unit is low except for when it starts up... you can hear the ticking of the ignitor and when it stops...the fan kind of makes a louder noise. Not terrible, just more noticeable. I'll try and get you the video as well as pictures of my side vent and I also have a neighbor who vented his through the roof of a new stand alone garage. He said if he had to do it again, he'd do it out the side like mine.
2Convertibles
Pittsburgh, PA
Here's my vents...I need to measure it, or put something in the picture to show the relative size. The one by the gutter and bush is about the size of a volleyball. That's out the side of the garage on the driveway side. I don't even notice it any more. The other one is smaller...about the size of a cantaloupe! It's out the back of a new garage. I'll be able to get a picture of my neighbor's vent by the weekend. I'd go out the side of your garage if it were me. It seems easier, less expensive and no worries with snow.
zmotorsports
Northern Utah
I mounted my Reznor UDAP150 using option #1. Mine goes straight up and is about 5-6' from the eve. We get snow here in Northern Utah as well but no issues with even coming close to the exhaust flue.
E
ED26
MI
I’m thinking of going verticals about 18” from shingles. ...can you upload video to YouTube?
MeBunkerYou
MN
Do you remember what brand vent cover these are? Cat III?
