Ridge vent and baffles
MostH8d
I'm getting ready to begin installing baffles from the soffit to the ridge vent in my garage attic so I can then begin insulating. I noticed my ridge vent oesnt go all the way across the peak. It stops about 3' from each end. Should I still install baffling in that section from soffit to peak?
Sent from my SM-G935V using Tapatalk
MostH8d
I will be insulating all the way to the peak. I use the garage attic as storage and have a full size staircase going up there.
MostH8d
Yes upstairs and downstairs will be heated. There's a full size stair case that goes up to the attic so I don't have anything to stop the heat from going up there anyway.
MEngineer
Everett, Wa
If there is no way for the heat to escape from those bays you will have trouble. Each truss bay needs adequate venting. Therefore yes, I would recommend to put the baffles in the "unvented bays" and then figure out some way to connect them in the peak so that they are vented.
