Rimac Valve Spring Tester
Dave33
Wilton, NY
I bought a vintage Rimac Valve Spring Tester that I think is a model 500 but not sure. It's had a rough life and in need of some TLC. I'm looking for anyone with information on where to buy replacement parts (if you can). Mainly, I need the bezel and a new plastic lens. The horizontal and verticle shafts are worn but I'm thinking they can be bushed. I will clean it up inside and out and have it powder coated and chromed. I will use it once in a while but I want it to be a conversation piece. Any help is really appreciated. Thanks.
If that fails, I suspect if you google
plastic clock lens
You can find the one the right size
The bezel might be a bit harder
Clock lens bezel
got some parts hits, but adding "aluminum" took me to clocks
Ricky Joe
Roanoke, Va.
I’m willing to complement you on having that. I’ve always built my engines with a Blue Point equivalent. It always surprised me that the old build books never addressed valve spring tension. To me, that is just as important as blueprinting.
D
Dave33
Wilton, NY
Good news. I was able to contact Rimac and they have the bezel, lens, and a new face. Not cheap, about $100 but a good start.
Ricky Joe, yes valve spring pressures are critcal especially in a race engine which I build occasionally for my son. This is a great tool for this.
  • Like
Reactions: RTM
D
Dave33
Wilton, NY
Just a quick update. I received the new lense, needle, and chrome ring that goes around the lense. I bought some stainless screws to replace the crusty old ones. I dissambled the unit completely, had it cleaned and bead blasted. Primed it today and am know looking for a paint that is close to the original. Once I have it back together I'll post some pictures of the finished project.
Also, calibration spring is on the way from Summit Racing.
