Kids went back to school Monday. I ended up taking this week off - what better way to start the year!
Have not touched the green 2 door in a while, so time to make some progress on it. Finally got a shot of it next to my black 99.
I really had a bunch more grinding and cutting to do on the floors. Been putting it off because it's just miserable work. Finished up on the passenger floor, and the 3 rusted sections on the transmission tunnel. Not much left over here
This did make it very easy to locate all of the exhaust leaks (there are multiple)
Onto the passenger side. A much smaller section needed to be cut out. Was able to flap disc most of the rest of the rust down. Will POR-15 everything, and then bond new panels bonded in place.
I didn't have the courage to break out the panel bond just yet, so I moved onto addressing the seats. They were all pretty nasty, as you can see here. The drivers seat was the worst.
Stained, ripped, and the seat frame was broken in 2 places (common XJ issue, they break at the welds). Thankfully, I saved the entire original cloth interior out of my 99 when I did the leather swap. Only problem is that the 2 door models have the feature to tilt the back rest forwards so that you can access the back seat. I was pretty sure that the rest of the seat components were the same, though, so I began disassembly to investigate.
Thankfully, I was correct in my assumption. I was able to remove the recline mechanism from both seats. The 2 door is on the left, and the 4 door is on the right. Note the additional tilt lever.
I swapped this mech into the set of 4 door seats and bingo! The seats are a slightly different color than what came in the Jeep (charcoal vs mist) but that's A-OK in my book. I have the rear seat to swap as well so they will all match. And the mist gray XJs are a combo of gray/black throughout the interior anyways, so it all blends in.
2 seats done! Much better.
Had to make a small incision at this seam so the tilt lever cold poke though. hmm looking at this photo, it appears as tough I forgot to tighten a trim screw
I found someone selling a parts XJ in the next town over. I've been toying with the idea of snagging a parts jeep to have on hand, so I went and checked it out. It was way to beat up for me, but it had a nice set of Husky molded floor mats in it. They sell for about $370 new for the complete set. I offered the guy $80 for them while I was there and he said sure, take 'em. They cleaned up well. I also ordered a new carpet for the passenger area of the jeep, seen in the box in the back.
Slowly but surely, it's getting there.
Finally, I grabbed this with the recent 25% off coupon at Harbor Freight. Primary use is to have it for winching non running vehicles up on to my trailer. I'm going to mount it on a hitch mount, and come up with a way to add a 2" receiver to the front of the trailer. This way, it doesn't stay outside all the time, and I can also mount it to the front and rear 2" receivers on my Jeep if I ever need to.
And that's it for now! Hoping to keep up the progress through the rest of the week.
