Mr. Roboto
I was able to work out there Saturday all day. Sheetrock is now 95% hung. I just have to finish some of the smaller areas around the garage door openings. I also changed my mind about a few electrical things so I ran one more 2 gang electrical outlet in between the 2 garage doors, and also mounted my generator inlet there as well. The left wall of my garage was all hung using 5/8" fire code drywall because I'd like to attach it to my house someday and damn...that stuff is heavy in a 12 foot sheet!
Crappy iPhpone panoramic, but you get the idea. You'll notice that the area above and below the subpanel is open at the moment. I decided I am going to patch in 2 sections there that will be removable in case I ever need to get access to run additional electrical services.
This is in between the 2 garage doors. I added the 110 outlets here just for convenience sake, but also because I'd like to get a small wall mounted shop/canister vac mounted here for vacuuming out my cars. The large gray box is the power inlet for my generator. I didn't like how I had to run the 2 pieces of strapping to support the box, but the thing is pretty heavy. I didn't want to leave it up to drywall anchors and/or toggle bolts to support it. Hopefully once I just paint them the same color as the wall, they will blend in. They are screwed right into the studs.
I know from recent experience that it can be a long and drawn out process. The garage looks great.
