I was able to get out there for a few hours yesterday and finish out trimming the windows and doors, threw up the outlet/switch covers, as well as started to get the flooring down. It seems to photograph darker than it is in person, but I really like it. The saleswoman at the store was trying to convince me it would be too large for the small room, since the planks are 9" wide x 6' long, but we couldn't find a similar color/pattern that we liked in a smaller size so we went with it anyways. I think it looks just fine! It's COREtec Plus XL Enhanced, and the color is Teton Oak (for my own future reference, and if anyone else is interested.
The trim is looking great, nice work.I'd give caulking the edges where it meets the wall a try, if there are gaps. You could do on a side that's not as visible first for "practice". It's a small detail but can really make it look seamless. Again, I'm no expert, but my tips would be:
- regulate the bead size by not cutting too much off the tip of the caulk tube. A hole the size of a #2 pencil is too much. I'd do like half that and see how fast it comes out. Can always make it bigger, but not the reverse. If too much comes out too fast, it can get messy and hard to control.
- apply a thin bead by gently applying consistent pressure on the trigger and moving down the trim. On a vertical section I'll usually do about half in one go. On a horizontal section I'd apply caulk to the whole thing in one pass.
- then just stick your index finger in there at an angle and run down the trim caulk line, smoothing it out. If it starts to bunch up and collect too much, stop and wipe your finger clean with a rag and then continue. If there are any lines left behind, just wipe them away with your finger as needed.
- if it doesn't fill the gap the first time, you can always add another bead of caulk and rinse and repeat. Don't keep dabbing your finger in there trying to fix it. It's kind of like drywall finishing... take a pass, smooth it out, do it again if necessary, but too much fiddling can junk it up. Similarly less is more... if you apply a large bead, it's going to bunch up and get messy.
- it's totally doable freehand, but you could use painter's tape for cleaner lines as long as you remove it before it dries.
It's not high-risk, either... if you screw it up horribly just wipe it out with a wet rag before it dries
I don't think the flooring planks are too big, they look just fine.
We have the COREtec product in our bathrooms and it was installed almost three years ago. We really like it and have had NO issues.
Thank you very much!
I started out trimming out the windows and doors. Anyone have any recommendations on filing the nail holes and closing up the miters? I’ve read some saying paintable caulk, others say wood filler. I’ve never really done any finish interior trim so I’m not sure which way to go! As you can tell from the pre primed trim I used, I’ll be painting it white.
Nice work it looks really good
[emoji41][emoji1303] good work, man!
I see there is snow outside; is it comfortable in there?
You may have already started but I use spackle (or drywall mud if it's all I have on hand). It doesn't shrink and it's super sandable so it's easy to get a very smooth finish. Since it doesn't shrink at the first weather change all your nails holes won't sink and reappear. Just make sure to hit the spots with some kilz, bullseye, etc, some type of drywall primer or else your paint sheen will look a little different over it.
Looks awesome! That trim looks fantastic. Mind sharing where you found the info on coping/hogging the trim with the grinder?
Wow time is flying I remember what 3.5 years ago you were saying your wife and you were having a baby.
Things seem to going well wish you a happy 2020 and more.
Coping is 100% the way to go on inside corners, I think. Your work looks very precise, nice job! I've never done a profile that complicated but the angle grinder is a pretty neat trick, thanks for sharing.
My daughter also loves watching me work out here. She asked if we could lift her toy car up to work on it, so I gladly made that happen for her.
Most excellent!![]()
Love those digital pressure gauge/fillers. I use one on our car tires and it works great!
I've been looking at inflators. Reviews are all over the place.
How do you like the Jaco? Amazon has it for $40 - don't know if it's the same model you have.
Just finished reading whole thread.
Good work on all the improvements.
Nice work in there. The pic of your daughter in the space is precious.
Did you ever get the doors replaced on your cabinet?
I was also wondering how you mounted it up above the bricks. I need to do something similar with a Husky cabinet.
Finished up my cheap bench for the mud room. It will do the job! For the price of six 2x4s, I think it turned out OK.
Looks great. Nice work, man!
Superb! Keep on sharing!
That bench came out real nice. If you do eventually replace it with something fancier, that will be a great accessory in the garage. Every time you need a stool you'll have one that allows you to do the job with fewer ups and downs.
The same goes for all the temporary rugs I have thrown down in there as well.Thanks everyone! I say the bench is temporary now, but we all know it will probably be there for the next 20 yearsThe same goes for all the temporary rugs I have thrown down in there as well.
