tigercreek
- Joined
- Aug 28, 2017
- Messages
- 41
I've been a longtime viewer and finally joined.
I was given an old 17-600 (1964? #1339409) if I would come and pick it up. Can't say no to that!
It was stored in a covered and semi-closed shed in South GA.
It is in poor shape BUT, amazingly enough, fires up and works without any obvious problems.
My questions concern missing, missing/broken, broken parts.
Many of theses parts may be impossible to fin/replace/repair and I wouls like advice/pictures/help in what things should look like, what I need to worry about and what I don't.
A - concerns the feed dial. It is missing and I can't even find a picture of what it should look like. Does this control the set depth of the drill?
B - concerns the crank/gearing assembly which appears to have never been there. Does this control belt tension?
C- concerns the hub. One handle is still there held in by a screw. Really bad shape. Would a Clausing hub work as a replacement since these seem to be hard to find?
D - This DP has no on/off power. Would it make good sense to install an old on/off switch here?
Finally, here is a pic of the motor that was used to replace whatever was here originally.
Thanks for any help/tips you can send my way. I'm sure I can bring this back to a much cleaner, working machine - but I don't want to be going down a road with no good ending.
