Roof Trusses Built for Trolley Beam?
Muckin_Slusher
Abitibi
Everyone says not to attach a trolley beam to the bottom chord of roof trusses 'cause you'll die.
Why can't I find any trusses that were made (engineered) to also hold a trolley beam?
What does a regular garage roof truss look like that was stamped to also hold a trolley beam?
Firebrick43
West central Indiana
Because you haven't been to a truss company and talked to the engineer yet.
Um, they are typically not actually "stamped" on the truss itself. The plans are stamped by the engineer. Its highly unlikely to have any existing truss not specifically designed to support the dynamic load be approved for a trolley
LopezBart
Lopez Island, WA
Trusses are engineered per-application (usually via a canned software program, but I digress). There's no such thing as a generic truss; each design is affected by things like overhangs, snow loads, local seismic dangers, etc. Note that trolleys can subject trusses to very high loads in a location where most trusses aren't designed to handle much load.
Muckin_Slusher
Abitibi
I am not talking about adding a beam to an existing truss. As I said, everyone knows if you do you'll die.
I am asking why I can't find any pictures or reference on google that shows some guy who built a garage and had trusses designed to also support a trolley beam.
I know there is not a "generic" truss. I know they're all custom built/engineered, etc. I'm just referring to the standard 2x4 and gang nail trusses that your see used as roofs on regular homeowner type garages.
Surely somebody has asked their truss engineer guy for this and took a picture and posted it online.
mike93lx
Richmond, VA
You don't site build trusses like this. Just email your local truss company with details on what you want and they'll send you a design and a quote. It's not a big deal
  • Like
Reactions: kwb
mm08822
Maybe you should be that guy.........
Muckin_Slusher
Abitibi
I didn't say I was going to site build anything.
I'm asking why I can't find any pictures online showing trusses that someone bought and installed after doing exactly what you just said, having a truss company design, quote and build trusses made to also hold a trolley beam.
mike93lx
Richmond, VA
I have no idea. Ask google
Why are pictures so important? And what will they do for you?
finn
The UP, God's country
You’re asking for a custom design, which can be done by a competent truss manufacturer, if custom designs fit their business model, ie it’s something they want to do.
It’s unlikely you’re going to find an off the shelf truss that meets your requirements, though.
call your local truss suppliers, and they can create what you want, again, if their business model supports this type of work.
Expect to pay a premium, though. 10x over a standard offering, or more. is my uneducated guess.
Uncle murph
Harford county
The question doesn’t make sense,the beam carries its load,that’s why it’s called a beam.Trusses are designed to support the roof and ceiling.You can request anything you want from the truss manufacturer but I can’t imagine anyone actually doing what you’re suggesting let alone photographing and posting it.
Stuart in MN
Minneapolis
Because not that many people are planning on putting trolley beams in their residential garages. In an industrial or commercial shop they most likely will have a bridge crane that's separate from the roof trusses.
Firebrick43
The truss carries the load if the beam is hung from the trusses. It’s done all the time in factories for bridge cranes. Millions of old big barns did it for the hay trolleys and the last of them used engineered trusses, usually of the gambrel style.
It’s not common in residential/ag shop but it can be done. Hard to take a pic after the fact. Carrying a good camera with you at all times(cell phone) is a relatively recent thing.
I never understood the appeal of a trolley. It’s only one path and covers very little floor area compared to a self standing bridge crane or gantry on casters, or even a swinging gantry
kwb
PNW
Engineering the truss for these loads is just a matter of the conversation with truss designer and letting them know where these extra point loads are going to be.
Trolley is kind of limiting but they have a place.
It would be easy to use a KBK type rails to create a bridge system that could be suspended from the trusses. You could be powered or unpowered. I bet they even have engineered anchors for wood structures once you start talking to your applications engineer (crane salesman).
You are going full custom at this point. Very doable technically but financially insane for most residential applications.
pbon
How much weight will the trolly be asked to carry? Could the load be spread by laying upright 2x6 beams perpendicular to the trusses on top of the trusses and then maybe framing down to the ceiling level and attaching a couple of 2x6 to the framing and the trolly to those 2x6?
jkeyser14
(rural) Maryland
You don't see it because trusses that could carry the load of the beam + payload would be stupid expensive and not easy to put the beam on the trusses during construction due to a minimum wage carpenter's ability to hold tolerances on the truss spacing. It would be far cheaper to just design in a bridge crane where someone bolts together a few pieces of steel.
Price ranges for bridge cranes:
micromind
Fernley, Nevada, about 30 miles east of Reno.
I would imagine this would be the same as having trusses built that can have storage on top of the bottom chords. They're a bit more $$$ and of course require special engineering bit any truss company could handle it.
It's easy to tell if the trusses were designed for weight on the bottom chords, they'll have vertical members at the clip (splice) points. The purpose here is to transfer weight on the bottom chords to the top chords.
finn
There are standard catalog offerings from all truss manufacturers.
The Menards website has pages of standard trusses. Menards owns the truss manufacturers.
My local lumberyards deal with a couple of semi local truss manufacturers who have catalogued trusses designed for different snow loads, etc in our area.
That said, a structural engineer with a PE license can design what he wants, at a cost.
WisJim
Menomonie, WI
Regarding the cost of special trusses--for my shop/garage, I used gambrel attic room trusses from Menards that were different than anything in their catalog. I ended up talking and emailing an engineer about what I wanted different (maximum height, floor loads, etc.) and the custom truss they supplied was only a few dollars more than the closest stock design that they offered, and only took a couple of weeks to be delivered. Of course, I live about 22 miles from their truss plant in Eau Claire, WI--but the engineer I talked to was in one of the western states.
zimman
Mark Twain National Forest
They don't make them because you'll die. You said it. LOL
Zim
cannuck
Rural SK
IMHO where you will find difficulty is in passing the load in tension from the center of the bottom member to the roof joist compression members. Conventional trusses are "nailed" together by rolling a barbed steel plate into place, but that kingpost in the middle is in compression and could do its job using a roll of Scotch tape. The concentrated loads in the middle aren't well suited to the hardware they normally use.
I would strongly suggest building a proper bridge crane free standing inside. We have one building with a central beam lift, but it's main job is to hoist a platform or load onto the mezzanine, so little need for transverse travel but a genuine PITA when loads are not on center. Other shops all have bridge cranes and once you have used one, you will never go any other way. I build my own using 12VDC RV winches or hand chainfalls and have several in the 500 lb. to 600Kg range. Would be glad to help OP offline with some design suggestions.
Muckin_Slusher
Abitibi
Financially insane?
Would that not also apply to "attic" trusses?
If a truss built to hold a load on the bottom chord was crazy expensive (be it a trolley beam, or attic floor) then you wouldn't see attic trusses being built. You would see people frame up a full second floor, then put the roof trusses right on that floor.
Does that make sense?
mike93lx
Richmond, VA
Financially insane?
Attic trusses are very different than the loading you are talking about
duneslider
Riverton, Utah
The truss may or may not look any different and pictures may not show anything beneficial. You just need to call a truss manuf and ask for what you need. Stuff gets hung from trusses all the time and they can design for just about anything that you want to do. They may also make a truss for you but they won't call out how you should hang your beam from the trusses, that would be a different engineer that will handle that part.
The company I work for does cranes (bridge, gantry, jib, etc) and we almost never hang cranes of any sort from roof trusses but these are all commercial.
cvairwerks
Within hearing distance of Texas Motor Speedway
Once you go past a 16' wide truss, you are going to run into some design problems. Most non commercial trusses have a lower chord splice if the truss length is greater than 16 feet. Wider than that, you may have to switch to steel trusses. Only a truss designer with a stamp can tell you for sure.
mike93lx
Richmond, VA
Guessing that a multi layer truss could be used, like is often done with girder trusses
ddurrett896
VA
why not just get a steel beam that spans the truss width and add a couple jack and king studs?
Muckin_Slusher
Abitibi
Because a beam that can hold 1 ton or 2 tons and span 40 feet would be very, very tall and very, very expensive.
If the trusses were designed to hang a beam I could use a cheap, small beam (like 4") and not lose 20" of headroom under the existing trusses.
firebirdparts
Kingsport, TN
I don't know about any universal negative, but I can guess. I guess nobody bothered post such a picture or, if they did, the context and keywords were such that you didn't find it. There's no benefit to posting pictures on the internet. You just have to be sort of an extrovert in that way.
LopezBart
Lopez Island, WA
Likely insufficient google-foo, grass hopper.
Seriously, this doesn't make any sense. Buy a gantry.
cannuck
Rural SK
Let's start out with your building dimensions. Also: when you say spanning 40' that seems a little wide for most wooden trusses. Finally, the load you would be putting on a 4" beam between trusses spaced ?? apart is not going to be 2 tons, so tell us the details of what you've got and what you want. Finally, you said "existing truss" so is this building already up? Do you have any zoning height restrictions limiting your ceiling height? There are many ways to limit the depth of crane trolleys on their bridge or beam.
zimman
Because that's not how this works. That's not how any of this works. LMAO
They don't have "Truss Stores" You have "Truss Manufactures" Take your drawing to the Truss Maker and let him chuckle....wait......design one for you. Report back.
We'll be waiting.
Zim
whateg01
doo dah, kansas, usa
Those don't look like the trusses op was asking about.
Muckin_Slusher
Abitibi
I don't have building dimensions because I'm not putting up a building.
The 40' I referred to was a beam length. That beam would be perpendicular to the wooden trusses. It could be a 40 foot long building that is 12 feet wide. Or 30 feet wide. The trusses would span the smaller dimension. You could have a 1000 foot trolley beam in a 10 foot wide building.
When I said "existing truss" I was responding to ddurett896, stating that if you want to freespan 40' under existing trusses and hold 1 or 2 tons you're gonna need a ******' huge piece of steel to do that, and you're gonna lose that headroom under the existing trusses. If you had trusses designed to support a beam, then the beam could be much, much shorter, since it'd be supported every 24 or 16 inches.
Did you even read this thread? Am I being trolled?
There's tons and tons of posts about someone wanting to hang **** from their conventional "homeowner" type wooden trusses and there's always people responding that the trusses are not designed for that. And they're correct.
I want to see what the correct, engineered way of hanging a trolley beam on common trusses looks like, and I'm asking why I can't find any examples of common, conventional wood/gang nail trusses that were built to hold a roof up and a trolley beam too (except for tamry's post).
This is a theoretical discussion. I'm not building anything, I just like the conversation and the chance to learn and better understand how **** works.
I very much doubt that it's not done because it's cost prohibitive. People pay dumb money for stuff all the time.
I very much doubt that "it's been done, but nobody took pictures". It's 2025. If something's been done, there's pics online of it. This subforum is for people to show off their junk.
I know that it's not impossible, because nothing is impossible; I'm not an engineer, but I know for sure that if I take some conventional trusses and fully sheath them on both sides with 3/4" plywood, and put them on strong enough walls then I can use those trusses to hold up a little trolley beam that I can lift things with.
Is it something that's not common? Well obviously yes, since I can't find examples of it online...
Muckin_Slusher
Abitibi
I had these designed for a trolley and stiffer upper floor cause I hate bouncy floors. 32’ clear span. Attaching them correctly to the trusses is the important part.IMG_0070.jpegIMG_2010.jpeg
That's awesome, and very nice! Thanks for posting.
What's the height of that beam?
Do you know how the beam is attached to the trusses?
Are they regular floor trusses?
