housewolf
Thanks in advance for any good advice I may get here.
My garage is 24’x32’ with an 8’x12’ corner of it framed out for an office. The office is insulated and has a mini split on the wall. No insulation anywhere else in the garage. There is a finished room over the garage that is spray foam insulated. 5-1/2” on the roof and 3-1/2” on the gable walls. There is no insulation on the (2”x10”) floor. The floor is 7/16” plywood with a layer of 7/16” OSB on top & LVP on top of the OSB. When the outdoor temps are 95*+ I can’t keep the room below 80* running an 18K BTU mini split on the bottom of a wall. We live on a lake and have guest pretty regularly that we’d like to offer the room to but I can’t consistently keep it comfortable. My shop is an 18’x36’ metal building with foam insulation and the same size unit, I could hang meat in there.
The window on one gable end is double pane and it’s not practical to do anything beyond tint there. The door on the other end is poorly sealed but I’m thinking the floor being uninsulated is the main issue. The bottom of the floor is ~90* in the heat of the day. Of course the flooring is about the same temp as whatever the room happens to be.
I can just “throw money at it” and get the spray foam guys out to do the floor but it would be invasive and cost less if I (DIY) attached foam board to the plywood below. Is the floor even the problem ?? How important is it to seal every single crack/gap in the foam board?
FWIW; the building is what’s left from our old lake weekend cabin after a tornado. We built a new house next door and live here full time now. In other words; it’s not what I would have built “from scratch”, I just kind of played the hand I was dealt. The whole project is a DIY, reclaimed material, shoot from the hip sort of thing.
Pics for reference -
