Rot Quest
andyvh1959
Green Bay WI
The rot quest on my 1973 contemporary house continues. Last fall was the entire rear wall of the living room, replaced the two 8' patio door and one wood post with three windows and one door, now framed with three posts. Then the 8' pario door in the dining room came out, rot removed and framed in for three windows. Last month outside the back of the living room I replaced a 4' section of rotted sill behind the rotted cedar siding, made cedar siding to match/blend into the original siding. Everything I replaced is with direct burial/ground contact rated lumber, flashings, spray on seal coating and then siding. Triple the level of moisture control this house never had from brand new.
This month attack the north side front door/wall in the atrium. Haven't been able to open the front door for three years because the windo/wall settled onto the solid oak 42"? wide door. as the sill plate rotted out. And two thermopane windows had sagged down at least an inch. So I took off the inside trim and dug out (by hand) what was left of the sill plate to get to the top of the foundation wall. This week me and a friend will build the sill and window framing from the inside. I already used my 2-ton bottle rack to raise the wall framing enough for a temporary brace. The west side of the atrium wall is the worst. The east side is actually solid, and I am soaking it with wood preservative (which makes it darker). Such fun in a weird house.
I figure if I had hired this all out I'd easily be well into $20,000 of replairs. The six wndows and one door alone cost me $9000. Maybe $500 in framing materials. This 1973 hoise keeps improving.
A
andyvh1959
Green Bay WI
I've been dousing (spray bottle) the good side with an old gallon of Woodie Penta I had for at least 20 years. But I'd prefer to use Copper-Green Wood preservative, if I could find it anywhere. HD nope. Lowes nope, ACE nope. Even Amazon, found it but they won't ship it.
A
andyvh1959
Green Bay WI
I wonder though if that is the same or as good a product as the Copper Green brand.
I was able to order the product I want through Lowes with free shipping too.
As I was prying the interior trim off (1x8 cedar) I had to be careful as the rot left the bottom of the wall barely sitting on whatever rotted sill remained. If I pried to hard the entire wall would move. Code back in 1973 allowed for a 14' tall load bearing wall of seven thermopane windows and one 42x92 solid oak door to be framed into ten 2x4s stick wall. Guess its ok since it has survived 53 years of WI weather. If I had built this house that wall should have been at minimum 2x6 framing. Didn't even occur to me when I bought this house in 2002.
PWC Repair
Arkansas
I need to do some work on my old 1958 model house as well. Mostly leveling and building a stouter girder beam but I have SOME wet wood as well.
Dumber than lumber
I know that copper stuff is good. But you might want to look into the Bor8 rods. Disodium octoborate. It can be bought in a form that is like a glass dowel.
When water reaches the rods they start to dissolve or melt and the wood gets infused with chemical. The product is used in wooden telephone poles and those poles have a 50 year service life when treated with borate.
A
andyvh1959
Green Bay WI
Just received my order of Copper Green from Lowes. I had planned to spray the areas of the original framing where possible to help preserve some of the original wood. First off, I have always had a strong tolerance to chemical smeels. But, when I opened the jug of Copper Green and got one whip, it hit me right away. No way will I apply this product onto wood inside the atrium. When I complete the new framing I still planned to take off the outside trim to apply proper flashing and sealants to protect any new framing. I'll only apply the Copper Green on the outside when I do that work.
A few comments above stated the strong smell of the Copper Green, and I have to agree. I got just a small wipe of the product on one finger when I opened the jug, and the smell was so strong in just minutes that I washed my hands a couple times.
