TT_Vert
After looking at the attached specs it appears that a 30A breaker would be acceptable. Am I interpreting this correct? Do I need additional overhead here? If that is the case I assume 10AWG would be acceptable but my question is, at what distance do I generate enough additional resistance to force me to step up in wire gauge? I already have one 220 outlet which is going to be for my compression and i believe I have extra room in my sub panel to add more breakers. I am going to trace my wiring (Finished walls/ceiling) and see if I may be able to just convert one of the 110V circuits to 220 and utilize its conduit and well exits as I'm not going to rip out drywall to run wire (NO attic). If I do, would i be better suited putting in a 50A breaker and running 6AWG and having all of my 220 devices (Minus compressor which will remain on it's own dedicated circuit w/ my lifts) for everything on the same circuit. The only things I can see running 220 would be a plasma cutter or a welder as of now. I would not be using either of them at the same time however. And given the ceilings in the garage are 12' tall, the depth of the garage is 22' I'd be at about 52' from the electrical panel to the closest wall outlet. About 80' for the furthest. OR the easy way, I just put one 220 outlet right below the electrical panel and run an extension cord to the device I'm using.
What do you guys think is best?
Dave
Dave
