Unsubscribed.
E ez-duzit Well-known member Joined Jun 24, 2013 Messages 5,097 Location Marina del Rey May 2, 2018 #41 Unsubscribed.
OP T TT_Vert Well-known member Joined Mar 9, 2018 Messages 1,436 Location Wauconda, IL. May 2, 2018 #42 ez-duzit said: Unsubscribed. Click to expand... LOL, the rest of us can go on now knowing this, thanks!! Dave
S sreeb Well-known member Joined Jul 29, 2009 Messages 460 Location SoCal May 2, 2018 #43 I can't speak to the code. Possibly you need to install a box cover with a hole and install a coupler between them. Is this going to be inspected? If so, you may want to ask the inspector what he wants to see.
OP T TT_Vert Well-known member Joined Mar 9, 2018 Messages 1,436 Location Wauconda, IL. May 2, 2018 #44 it will not but I want to do it properly. I will research my existing codes. Dave
P pattenp Well-known member Joined Jun 4, 2008 Messages 10,175 Location Virginia - USA May 2, 2018 #45 This is the A/C disconnect I used..... Square-D QO200TR, It's a nonfused switch rated at 60A 10HP. https://www.homedepot.com/p/Square-...kW-Non-Fuse-AC-Disconnect-QO200TRCP/202353314 View media item 16457
OP T TT_Vert Well-known member Joined Mar 9, 2018 Messages 1,436 Location Wauconda, IL. May 2, 2018 #46 Yeah googling this brought me to your picture. I ended up w/ the same box. Is that the ac non metallic whip also? Dave
P pattenp Well-known member Joined Jun 4, 2008 Messages 10,175 Location Virginia - USA May 2, 2018 #47 Yes the whip is a non metallic ac whip.
W wyliesdiesels Well-known member Joined Aug 14, 2012 Messages 20,004 Location Modesto, CA May 2, 2018 #48 TT_Vert said: Ahh so romex is not THHN, that makes sense. And mounting this ac disconnect atop the open single gang box and running wires though the knockout in back is acceptable? Thanks again. Dave Click to expand... NM-b (Romex is a brand of NM-b), while usually containing 90* c rated conductors, is limited to 60* c ampacity in 310.15B(16). For your 5HP motor, this means #8 NM-b because #10 NM-b is limited to 30a and 5HP motor requires 35a rated wire.
