Running electric wires and cat 6
alex2929
I am working in a bar room. I have the electric mostly done. I need to run some cat 6 to tvs. I’m also putting in a home theatre system with some keypads and stuff for different zones that is controlled through network cable. How careful do I have to be with running this stuff next to romex?
dcg9381
Austin, TX
I've had zero issues running CAT6 across romex - lots of runs between 100-150 feet. Shielded would be better if you are worried.
HDMI and romex - I've had issues with that.
A
alex2929
Thanks for the replies. Very mixed signals if you google it. I think ill keep it away if it works out...otherwise just go with it.
kTHREE
MN
Doing any distributed video or is this just for lan connection?
kbuhagiar
Escondido, CA
Many moons ago when I was doing it, we kept the voice and data wires/bundles separated (separate conduits, separate runs) as the ringing voltage on the voice lines could disrupt the Ethernet signals.
We avoided contact with any power wires, but it was OK if our voice/data bundles crossed paths at 90 degrees (but didn't touch) near a Romex or armored cable. We NEVER ran any voice or data wires or bundles parallel to any power wires.
Metal-Marc
Foothills of the Adirondacks
This.
JohnX14
Boston 'burbs
I agree with everyone here. Keep them separated by at least a foot when running parallel to each other and cross at right angles. I've been installing both for decades.
u3b3rg33k
disagree. improperly terminated shield wires will increase noise levels in the cat6. even pros have trouble with shielded because its not the standard.
dcg9381
Austin, TX
Lets pretend that shielded wire gets terminated properly.
The other thing that I like about shielded cat6 is that if you terminate it properly, it's better protected from lightening induction. I've had problems several times with shielded CAT5 and nearby lightening strikes.
There is this:
NFPA 70, National Electric Code (NEC) Section 800.133(A)(2) requires communications wires and cables shall be separated by at least 50mm (2 INCHES) from conductors of any electrical light, power, Class 1 non-power-limited fire alarm or medium-power network-powered broadband communications circuits. Exceptions are if separate raceways or conduit are used for separating the communications cables/wires from the power conductors.
