I am in the process of gut renovating a house. I have a contractor that is doing the plumbing, framing, electrical, etc.
However, I am going to run the network cable and coax cables for the various rooms myself, with the help of my cousin who is a network IT guy.
The question for the forum: Are there codes/things I should be aware of before I start drilling holes into studs? Obviously, I'll have an electrical and I assume plumbing inspection prior to sheetrock but I want to make sure I dont raise any red flags.
Thanks
Mostly no. Some locales have basic codes/rules in place, most of those are commercial-only. But most stay out.
Couple things:
1. Keep the low voltage separated from the high-voltage. If they appear in the same box, it must be divided.
2. Don't string low voltage cable immediately next to high voltage, it will couple noise onto the low voltage. Not a safety issue and not as relevant in todays digital age, but still a good rule. I usually run 120 down one side of the stud cavity, and low-voltage down the other. Perpendicular intersections between the two is not as bad if needed.
3. Don't stuff wires in HVAC vents because it's easy, it must be plenum wire if you do.
4. Holes in top/bottom plates usually need to be sealed to prevent fire movement. Your inspector will want to see orange expanding foam, or red fire caulk here. Orange expanding foam is the easy way to go. I seal up just about all my holes even if not required, it keeps air movement to a minimum and keeps wires/etc. from vibrating at the bottom of holes with deep bass
5. Don't be afraid to run more wire than you need. I usually do a minimum of one quad-shield RG6 and two Cat5E to each potential TV/computer location. Cat5 can be used for other functions too - you can use one for an infrared repeater, audio (with balun), HDMI (requires two, Cat6 suggested), USB, etc. Run 3/4" conduit to "popular" TV locations as well to future proof.
