Kevin54
MEMBER EMERITUS
I worked at a couple of shops that had O, ACT and Argon piped in the walls. Why is everybody assuming it will leak? If installed properly it would be fine. Do you assume the water pipes in your house will leak? Yea I know water won't kill you but I think you get my point. Oxygen has been piped in medical buildings as long as I can remember.
If it would make you feel better then surface mount it and use quick connects at the outlets.
Of course we are talking hard pipe here and not hoses.
Water pipes in a wall leak quite often. And comparing water to a gas mixture is two different ballgames altogether. I really hope you weren't serious with that remark. Do you EVER see natural gas lines behind a wall, Propane behind a wall, Oxy/Acet behind a wall? No. You know why? It's explosive. What do you think would happen if a pocket of gas built up in the same wall cavity as an electrical outlet, or a light switch?
