Questions:
Can I properly run Romex across the joists in the area that the rafters
come down to meet the wall or does it need to be put on a running board? The distance from the wall would be around 1 1/2- 2' & the vertical clearance to the rafters would be around 1' (+-) so it wouldn't be an area where someone would walk.
OR- could I run it across the bottom of the rafters which would be in that area about 8- 10" above the joists?
The attic access crawl space is at least 10-12' away from this area.
Thank You for the help!
