Rust between welded car panels.
Rustedtruck
Hello. I enjoy working on cars with the little time I got on my days off, be it mechanical, detailing, or metal work like looking for rust spots to fix. I recently bought a 2010 Matrix and have been looking for rust and trying to stop its spread. However, there are these couple of spots that I don't know how to deal with because the rust seems to originate from behind two welded panels. Any suggestions?
R
Rustedtruck
That is around the hatch frame on the inside and those bolts are for reinforcement I guess but the panels are welded.
beltfeed
USA
It's 15 years old, be happy if it runs. If that amount of rust doubles in another 15 years, it will still look better than a 10-year-old car in the rock salt northern states.
R
Rustedtruck
I actually have turned it a project car. It was originally meant to just be a beater as my son's first car but me being me had to go and start mending and tinkering.
Kaizen
New England
jeez.......pretty sure if i showed you a pic of any of my cars you'd lose sleep. When those two panels were spot welded it started rusting. Without doing some deep surgery to get to the root, Its not worth the effort. Maybe scratch and seal it with a rush converter and some paint will make you feel better.
racecougar
Missouri
FluidFilm is good, but you need to repeat every couple of years.
Some people swear by 3M Cavity Wax
Agreed that it's a better product, but it carries a much higher price tag. I did use it on a few builds, but switched to FF, as FF doesn't need to be reapplied often at all when used in cavities that don't see any real water/salt intrusion (the vehicles I'm working on don't go out in bad weather anyway).
R
Rustedtruck
Seems like a great product but if this seeps in between the two panels with the rust still there since i can't separate them wouldn't the rust keep spreading. I would have to get rid of that rust in-between first.
R
Rustedtruck
I would like to remove the rust but I'm not sure that's possible now unless I start cutting or taking panels apart which is not worth it.
Firebrick43
West central Indiana
Corrosion needs three things
Moisture
Oxygen
And an electrolyte
Fluid film or wool wax(I prefer since it doesn’t smell as bad) will keep all three from reaching the existing rust.
Even if it doesn’t stop it completely it will slow it down to the point that the vehicle will be worn out before it becomes an external visual problem of applied with some frequency
jack stand
Lakes Region Maine
On his apparently "interior" type panel(s) that are not subject to road spray from the tire area it should be fine for much longer if not almost indefinitely.
The creeping action is real and the hotter the weather at application, the better it will migrate between these mating surfaces that are very common since frameless cars are hundreds of little pieces of formed thin metal all spot welded together. 👍
R
Rustedtruck
I'll go ahead and do a touch up on those two areas without clogging up where the panels meet. Then I'll use either fluid film or 3M cavity wax in that crevice. Now comes the part where i turn a decision into most likely hours of research and where a storm starts brewing in my mind trying to decide which of the two products last and works best.
CraigStu
Blacksburg, Va
How about splashing the area w/ one of the rust remover/convertor liquids. Find one that is thin like water and see what happens. Then do the FF.
finn
The UP, God's country
At the most, spray a bit of Fluid Film or WaxWool on that cosmetic “defect “.
Trying to “fix” it otherwise will destroy the factory paint bond and make it worse.
If that’s all you see after 15 years, it will still be fine in another thirty years from a structural standpoint. That’s really nothing compared to a three year old car in the rust belt.
zendriver
Indiana
Scrub that rusty edge with a small wire brush, loosen the two bolts a bit, pry up enough to spray in some matching touch up paint.
Tighten the bolts, touch the area up and move on with life.
If it ever looks like it's rusting again - repeat. Rust work is mitigation, which can be good enough.
"why bother" just seems silly, IMO
yellowbox
Well yeah it is rust , but it is so so minor it will never amount to anything
Are you that worried about it ?
Have you ever seen a 15 year old michigan or new York or Pennsylvania vehicle?
Wrench97
Southeastern Pa
The only way to totally get rid of it would be to separate the panels, treat it, weld it back together and repaint it.
It will probably only rust again only faster, clean off what you can and cavity wax it if it ever rots all the way through then you can cut it open and weld in new metal.
NYBODYMAN
NY
Hate to say it but that's normal. I get your OCD though. I would just leave it and run the **** out of the car.
Glemon
NE
I would be jumping up and down celebrating my good luck if I bought a 15 year old car that looked that clean. As others have said, the car will die long before so.etbing like what is shown becomes any kind of issue. If it makes you feel better spray some WD 40 or PB Blaster on it and wipe it with a rag and I bet most of the runoff oxidation on top of the paint disappears.
R
Rustedtruck
Not that I will do that but hypothetically speaking let's say I managed to do all that. Why would it rust again if the rust was sanded off then primed and painted?
Jazz1
Thunder Bay On.
Spray it with some rust converter, once that dries some Fluid Film or similar product. Both products will leach inside there
andyvh1959
Green Bay WI
I bought a case of Krown corrosion inhibitor spray cans, bought on Ebay. Each can is large and goes a long way. Krown is likely similar to FluidFilm and 3M Cavity Wax. I bought a used 2009 Ford Escape with low miles and applied Krown underneath on the front subframe (which is known to rot to failure), and all the other areas known to suffer corrosion issues. That was last October, and so far from underneath after this Wisconsin winter it looks like when I sprayed it. I also sprayed it inside the doors, rear hatch, fenders, hood, etc. I had my 2019 Kia Sorento treated by a local Krown supplier before I had bought the Escape.
I don't know anything about Krown.
There is NO SIMILARITY between FluidFilm and 3m Cavity Wax. FluidFild is a lanolin (from sheep) based oil. Exposed to water, it will wear off is a couple of years. The 3M stuff is a "wax". Like stays longer than FluidFilm.
