Rustbullet
Jackfre
N CA
I did my shop floor 3+ years ago. It went in easily, covered well and looked terrific. I have fairly beaten the hell out of and am considering re-doing the floor with RB again. What is the process?
Shea
California
Rough up the surface with 120 grit sandpaper, sweep or shop vac, then wipe down with denatured alcohol on a lint free or microfiber towel. You can then apply a new coat or two immediately there after.
larry4406
Northern Virginia
Not sure what you do/did in your garage "beating the hell out of it" but I would be pissed at a only a 3 year floor coating life.
Garage Flooring
Grand Junction, CO
The suggested method for re-coating is almost always grinding off what is there and starting with fresh concrete. You can lightly sand the surface and coat over the top, but it is a huge risk.
If the original coating was Rust Bullet things change a little. Please let me know
J
Jackfre
N CA
Larry, the surface is not terrible in any way. I don’t care what you put on concrete, if you weld over it, etc you can damage the surface. If I clear the area and clean it thoroughly it will probably look fine. I am in no way dissatisfied with the Rustbullet as a finish. On fresh concrete it applied easily and looked great. I was just looking at it wondering what it would take to re-apply sometime in the future. And I would use it again!
