Rustoleum EpoxyShield top coat?
7palms
FL
So, I have a new garage on a new build home and had the builder do me a “favor “ and he coated the garage floor using Rustoleum 2 part epoxy kit. It’s not what I would have used, but it’s done.
I’m wanting to add a top coat to protect and increase the durability. I also want to add more flake than was originally added. This is a light use garage for parking cars only.
Questions-
-Should I stay in the same brand/ family and stick with the Epoxyshield clear coat for the topcoat? What about switching to the Rock Solid clear coat?
-Any other options to top an already installed epoxy floor?
-Can I add more flake during the clear coat process? Would I need a second coat of clear to lock the flake in?
Thanks
Garage Flooring
Grand Junction, CO
Questions-
Thanks
First, understand recoat periods. Once the floor is cured, you have to lightly sand and solvent wipe to recoat. I would suggest a clear Polyurea. We have one as does Legacy and Armorpoxy. Make sure you do a test spot first, but we have not seen any compatibility issues
Sumboodie
AK
The Rustleoum held up decent in my garage. Mostly welding and torch slag messed it up.
Probably just going to use floor/porch paint on my current shop. It holds up decent and at under $40 a gallon doesn't break the bank.
7palms
FL
Justin Thanks for the reply. Regarding recoat times, I specifically asked Rustoleum customer support if I needed to sand if using their clear coat. I also let them know the floor had been installed for about 15 days. They told me it was not necessary, just clean/degrease and allow to dry before using the Epoxyshield clear. Does that sound right?
FYI this is on a floor that has not been used, never been driven and parked on. We wont be moving our stuff in to this new house for another 2 weeks.
Shea
California
Rust-Oleum's customer service department usually is very good at helping customers with issues. Unfortunately, it isn't always the best in terms of providing the most accurate information. You have up to 4 days to recoat EpoxyShield before deglossing and roughing up the surface is required. You can find that information in their FAQ sheet here. It's number 14.
As Justin stated, a polyurea clear coat would be a great option. It will provide much better abrasion and chemical resistance than the EpoxyShield clear. Because the clear coat is the wear coat, the overall coating will last longer as well.
Garage Flooring
Grand Junction, CO
Thanks, Shea
@OP. Always better to be safe than sorry. Not a heavy sanding and should go quickly.
7palms
FL
Thanks for the info Shea and Justin!
What about adding more flakes? The original guy did a light flake in the floor. Id prefer to make it more of a medium, to medium + look. can i add more flakes to the polyurea clear? Will that require 2 coats of clear?
Shea
California
Yes, two coats of clear. The first to accept the color flakes and the second to coat over and lock them in. Justin's customer service is excellent, by the way. He will help you out with quantity and application if you contact him.
Armorpoxy
For something not expensive and little prep needed, consider a gallon of our Ultraglaze hybrid acrylic/urethane.
lamywaby
Questions-
Thanks In alcuni scenari, ci possono essere errori tecnici o altre interferenze che possono causare una diminuzione della velocità di Internet. Durante tali situazioni, gli utenti potrebbero non essere in grado di monitorare la loro velocità effettiva o la velocità attuale di Internet. Al fine di valutare la tua velocità di Internet Velocità, abbiamo sviluppato questo test di velocità appositamente per misurare la velocità di Internet fornita da Eolo. Utilizzando questo test, puoi ottenere una stima quando la velocità di Internet si riduce.
When considering a top coat for your garage floor, it is generally recommended to stick with the same brand or family of products for compatibility and optimal results. Both the Rust-Oleum EpoxyShield clear coat and the Rock Solid clear coat are viable options for enhancing durability and protection. If you prefer to explore other options, you can consider clear polyurethane coatings designed for garage floors. These coatings offer similar benefits and can provide additional durability. Adding more flake to the floor is possible during the clear coat process. You can sprinkle the additional flake onto the wet clear coat, ensuring even distribution. To lock the flake in and achieve a smooth, durable surface, applying a second coat of clear coat is recommended. This will help seal and protect the flake, giving it a consistent appearance. It's essential to carefully follow the instructions provided by the manufacturer of the clear coat product you choose, as they may have specific recommendations and guidelines for application and drying times.
7palms
FL
Armorpoxy,
What would the prep/application process be using Ultraglaze?
How about adding flakes to this product?
Besides adding the topcoat to the existing floor, I was also hoping to add additional flakes.
Thanks
Armorpoxy
Prep for any of our topcoat products would be the same, a very light sanding with a sanding pole and then wipe down with denatured alcohol. We would not recommend adding flakes to Ultraglaze, it's not thick enough to hold them. If you want to add flakes, then contact us about our one part Red Label Topcoat that is thicker and you can broadcast flakes into it, and then seal the floor with another coat of the same product. This topcoat is actually more abrasion resistant than our two part topcoats and most of our professional contractor customers use this particular product.
7palms
FL
Between the Ultraglaze, Red Label or SPGX is there a big difference in coverage per gallon? Ease of use?
This would be applied to a new floor w/ 3-week-old layer of Epoxyshield with light flake. Im right at 400 sq ft. (20x20).
Thanks again for all of the advice!
Armorpoxy
Ultraglaze being thinner would cover about 500-600 sq ft/gal. Red Label and SPGX would cover in the 350-400 ft range. We also would strongly recommend that no matter which you choose please use the Armorgrip clear non skid additive so the floor is not slippery. This would be added to the final coat that gets walked on.
For pricing/addl suppor please contact us directly at [email protected], thank you.
