Rustoleum Farm and Implement Paint + Hardener Question
Beamer
Northeast
Wanting to repaint our garden tiller Briggs steel gas tank and I am hoping to get some degree of accidental fuel spillage protection in the new paint.
Would adding a hardener to the paint (brush on) give it some degree of resistance to gas?
I don't know what they originally painted the tank with but it has held up very well for over 30 years. It does not appear that there was primer under the original paint judging by a small area that pealed off in reaction to carb cleaner dribble. Maybe that gives a clue to what they used but I can't find information on what might have been used.
Amy suggestions will be appreciated.
gte718p
Can't speak for rustoleum perse, but I did my 4runner in tractor supply implement paint with the hardener. No problem with small spill at the gas station for the five years I owned it.
rattle_snake
Chandler, AZ
The hardener is awesome. Reduces dry time significantly, hours instead of days. I don't spray without it. As for solvent resistance, I'd say no change.
Rustoleum Implement paint is an alkyd enamel. Add hardener makes is almost as tough as epoxy paint ! Not certain it will add to resistance to gas, but it is "good stuff" ! Chip resistant.
Alkyd enamels take a long time to cure. Not just dry, but to completely cure. I would leave it in the sun for at least 2 days, maybe even 5, before risking getting gas on it.
The Cobbler
probably baking enamel . it was heat cured , not to be confused with Powder coating
Can that be reproduced with a heat gun?
probably can't buy the paint . at least in a quantity that you would want
I thought you were asking if baking enamel could be cured with a heat gun. my reply was " probably can't buy the paint "
baking enamel is it's own special breed , not run of the mill alkyd paint
Beamer
Northeast
Never heard if it.
I was asking about applying heat to any enamel. I thought I read that engine enamel could be treated with a heat gun but perhaps that was AI's imagination at work.
Beamer
Northeast
I use Rustoleum Clear Engine Enamel (248944 Clear) as a topcoat when painting Coleman lantern and stove founts. Excellent fuel and oil resistance. It's also heat resistant to 500F.
That's over Spazstix Kandy Apple paint.
Now that may well be the answer to the question.
After looking into it, it appears to not need heat curing to resist fuel.
What type of paint is the Spazstic?
Asking to see what else the engine enamel can be applied over.
Sumboodie
AK
What hardener? I went to buy some at Carquest and there's like a dozen different ones.
Beerhippie
Far NE Oregon
I heat-cure my enamel paints. The Spazstix is also an enamel. The high-temp Rustoleums require heat curing.
Beamer
Northeast
The Engine Enamel a different product than the High Temp paint.
Run a search for: "Does rust oleum engine enamel require heat curing to resist fuel?"
It gives an encouraging no heat cure answer, but the validity is not certain nor is the source.
I have a request in with the company to get the official recommendation.
Beerhippie
Far NE Oregon
It isn't a High Temp paint, but it is. 500F is certainly higher temp. No, it doesn't specify the regime of heat-cure steps that a Rusto High-Temp paint does.
But I heat-cure all my enamel paints, so whatever.
gahrajmahal
Cincinnati, Ohio
I’d resist using a heat gun to cure paint on a Gas Tank unless the tank was empty and washed out with soap and water. Heat guns occasionally send a spark out with the air flow.
Farmall450
Marengo, Illinois
I've wondered about this, because Rustoleum doesn't rec'd a hardener with their paint. And my local farm stores don't even sell it (but they do sell another brand's hardener).
aka Larry
Eastern, NC
I use the Majic brand hardener from TSC with my Rustoleum Industrial enamel and it finishes bright and glossy.
This is the combination I use as well, with similar results. I mainly started using it (Majic hardener) because the normal dry times for Rustoleum are measured with a sundial.
Firebrick43
West central Indiana
Where do you see that their DTM paint doesn’t recommend a hardener?
Valspar hardener is the same, rust oleum is a valspar brand. The majic hardener at tough **** Charlie’s also works with it
Farmall450
Marengo, Illinois
I'm talking about the stops rust stuff, which on the label says no hardener.
Farmall450
Marengo, Illinois
FYI
Beamer
Northeast
After a correspondence with the R company it was indicated that no hardener can be added to the Farm and Implement paint as it would change the formulation.
Any long term result experience in doing so here?
