gogolf0401
after the wall girts are up, steel is next. I fount it easiest to abandon the scaffold and just use a ladder. I bought sheets to fit the walls top to bottom. Make sure you do your homework here before ordering the steel. You do not want to cut every peice to fit!
I decided to use "shelf" strips for at the bottom of the steel panels and j-channel at the top and around the windows and doors.
I don't know what this "shelf" steel is called.. but it's a different option than j-channel which looks better for at the base.
I used my air stapler to fasten the j-channel and shelf strips.
You will have to cut the steel if the floor is uneven in places and around doors and windows. For this I decided to use my circular saw with a cheap plywood blade ($1). You can use the expensive blades for thin steel, but I found that these throw larger slag than the smaller tooth plywood blades and cut marginally better. You will definitely want to buy a full face guard instead of just safety glasses. If you get this slag in your eyes you will have a hard time with infection.
Remember to put the cut sides in the J-channel instead of on the shelf strips to hide the ugly.
