L5wolvesf
I searched “Ryobi lithium battery test” here and didn’t find what I’m looking for. Is there a quantitative test for 18 volt lithium batteries, Ryobi in my case, which tells what the post charge condition of the battery is?
Preferably something I can do on a simple multi-meter.
I recently picked up a used battery, P103, and it stalls when using it on a reciprocating saw (older dark blue model). Another used P103 battery I have will work for hours on the same saw and on the same materials. Today I was cutting a 3 inch or so Manzanita branch and half way through that battery stalled. I pull the blade away and there is still power and when I try cutting again it will stall. Changed to the other battery and it cut through the branch like butter.
Same thing happens with an older sander and drill I have. I’ve charged all my batteries on 2 different newer (light green) Ryobi chargers and no difference.
I would like to show the seller the difference before I claim the battery does not “function as intended”.
Thank you.
Preferably something I can do on a simple multi-meter. I recently picked up a used battery, P103, and it stalls when using it on a reciprocating saw (older dark blue model). Another used P103 battery I have will work for hours on the same saw and on the same materials. Today I was cutting a 3 inch or so Manzanita branch and half way through that battery stalled. I pull the blade away and there is still power and when I try cutting again it will stall. Changed to the other battery and it cut through the branch like butter.
Thank you.
