84scrambler
I just bought an S4 in pretty descent shape. It seems only two things do not work properly, the light and the trigger for the handle position. I wanted to fix these issues and I started by going after the battery compartment. It looks like the batteries I found in the handle are as old as the jack. I removed a good amount of it picking away with a screwdriver and hammer but there is still a lot left.
I was trying to figure out how to remove the handle so that I can work on it a little easier. Anybody know how to remove it? I removed the two screws and I can get the handle to spin and act loose. Do I have to remove the linkage at the bottom of the shaft? I can see a hole at the base of the handle, is this some sort of pin I need to mess with? Thanks for any help..
