SAE vs. Metric, Any Preference?
theknurl
SoCal
Inches put a man on the Moon..........and sillymeters went where?
what % of the World's aircraft use sillymeters? lolol
what is the standard for plumbing in the World? SAE pipe
how about hydraulics? check the bore of the M/C on your Honda car/bike
what is the size of almost EVERY ball in a ball bearing??????
its fractional INCH !!!!!!!oh the ID & OD are metric but the balls aren't
what is the size of 99.99% of spark plug wrenches???? they are in inches
I know the Germans have a new one .......14mm 12point so every mechanic can buy a new
plug wrench........morons
what size are the wheels on your car/truck/motorcycle? they're all in inches
the 5.56x45 NATO round is what? .223 Remington
the 7.62x51 NATO round is what? .308 Winchester
and just for the GJ what size are your ratchets and extensions?
and what size is the chuck on your drill? .....yeah 12.7mm right
90% of the World's air freight is carried on Boeing aircraft........you think they need metric
wrenches to work on them......Nope :thumbup:
ChevyEFI
Phoenix, AZ
I hadn't thought of this before.
When I do an LS engine swap, my car will be far and away majority metric.
The SAE hold-out parts are on the engine. Wheelstuds and all body bolts are metric.
Delerium
Those answers vary depending on where in the world you are (except the aircraft)
oh and .223 != 5.56, and 7.62 != .308. there is differences.
hawaiiysr
Hawaii!!!
If I had the choice I would use metric for everything. Just makes life easier. But hey I'm no engineer. I just repair the engineers flaws.
HanShotFirst
NW Nevada
All my machine equipment is older US made (mills, lathes, etc.) and any time I'm working on those, it's all SAE. US Made cars/trucks are 90% metric with a little SAE thrown in there just to make sure you're still awake. Motorcycles, I'm into Japanese motorcycles because they're just plain the most reliable bikes in the world (I'd rather ride than wrench), and they're 100% metric with some very rare exceptions.
HanShotFirst
NW Nevada
I got ya...and I just can't wait for all that to change to metric; can't happen soon enough if you ask me. But it will take a LONG time for that to change (and you can bet your **** at some point it will change, just may not happen in our lifetimes).
Oh and technically speaking the 5.56 and 7.62 NATO rounds are NOT .223 & .308. In both cases, the metric military cartridge came first (even though both were invented right here in the good ole U.S. of A.) and the SAE designation civilian sporting cartridges came second. There ARE differences, but most of the differences are not something you can see. Regardless SAAMI will advise against firing the NATO rounds in the .223 & .308 chambers, but they're okay with it going the other way around.
The .223 & .308 rounds have very hard set pressure standards, where the NATO rounds pressures can vary from lot to lot and still be in compliance with the NATO "spec".
