I know the gentleman who owns this bus in Ohio (Brad) and this is not original sealing wax red. The bus is a very rare model camper and very complete but it has been resprayed through the years. This bus is often referred to as the pink bus.
This is my bus and original paint Sealing Wax Red:
Stay original colors....original NEVER goes out of style and will hold more value.
With a limited budget, the least expensive way to get it running is to rebuild what I have. I'm going to pour some Marvel Mystery Oil in the spark plugs to let it start soaking, unless I find something that works better. I grew up with this Bus and have helped rebuild the engine at least two other times. Now I will be channeling my Dad to recall how we actually did it. That and plenty of manuals and video's, I should be ready to go.I have paperwork saying it is S.W.R., but it was not the same bright color as yours. I guess I have more research to do.
Buffed with glazing compund. That would explain alot. Your Bus looked exaclty like mine when I brought it home! I guess that is the image of the color that is in my memory. I will check my plate tonight. I also have a sticker below the plate with the colors noted. Thanks for posting your 'before shot'
Update from my last post, I searched options for a good penetration oil and have ordered some Kroil. (link is to a special deal). I also want to try the acetone/AFT home brew that supposedly gets better results.
That is one nice Bus you have, dirtylawnchair. It seems I've admired it at Bulli Brigade before. I will have to check all the shots I've taken to find it. I love the stance. I will have to talk with you when I start to focus on dropping the suspension. For now, I know I have RGB's to work around in the rear.
When I saw Brad's Bus, it is what I remember the color of our Bus. I have paperwork saying it is S.W.R., but it was not the same bright color as yours. I guess I have more research to do.
For now, patina will be the color of choice for me. But after I replace all the rusted pieces, it will really need to be repainted completely. But it would not be unheard of to repaint a newly completed project with a patina finish. I keep thinking back to this '37 Ford with a fiberglass body
[Omph, I haven't really thought about a Corvair engine since there are so many great VW specific engines available now. I don't think this guy had an original 1600 cc engine in his ride.
If I would go away from VW, it probably would be a Porsche based engine, which for the most part are interchangeable.
Progress slowed on Saturday after the 3/4" breaker bar did.
nope that wont work
^^^ Dang Wingnut65, you must have gorilla arms (or a really long cheater pipe to slip on there!)![]()
Let me guess rear axle nutnope that wont work
Take about a 2 foot piece of flat stock with a squared off end (you might have to bevel the end to clear the wheel rim) and lay the end flush onto a flat of the nut. Use a 3 pound hand sledge to give the other end of the bar several solid whacks. Move the bar end to several other flats and repeat whacks. The idea is that the impacts momentarily 'deform' the nut's inner diameter thus (I love that word) breaking the mechanical/corrosion bond between the male and female threads, ergo (I love that word too - lol) the term 'metallurgical coitus interruptus'. I learned that technique many years ago from a crusty old drunk of a MCPO in charge of the engine room I slaved in for my Uncle Sam as a Machinist Mate. We had some humongous nuts on the steam turbines' casing studs. We used a MUCH bigger sledge and bar in that case! Oh, by the by, we found out that swearing at it does indeed help loosen tight nuts.
I will give the sledge-n-flat-bar method a try since I have not purchased an Ofishal VW Axle Nut Removal Whacker Tool...
***Progress slowed on Saturday after the 3/4" breaker bar did.
"DON'T MAKE LOVE TO THE %&$&#^$*#&%& NUT, - - - HIT THE G$* D(#(% F*%*%)$(# THING!!!"
My wife just saw this on Pinterest and I thought of you. Apparently all the VW owners are getting these toasters.
we need a link to that![]()
