Sams club LED'S
elknturkey
I just hung 9 in a 36x40. I will get a pic in a day or so. Got the power off wiring some other stuff. They are pretty bright
firworks
IL
They made a huge difference in my shop. I've got 3 of them hung in my single car and I can't even believe how little light I used to make due with. I might get a few more but It is a slight pain getting them all plugged in unless you have outlets on your ceiling.
TerryH
Springdale, AR
I added some to my shop for task lighting over my benches etc.. I love them. Super bright. I plan on changing out all my fluorescents to the led's as I can.
Catadj78
Alabama
9 was enough? Ceiling height? I have a 40x40 but 12x25 is office and bath. Still in progress though.
TerryH
Springdale, AR
elknturkey
10'6" ceilings. Yep 9 lit it up really good. I also hung 2 over my work benches. I did put outlets in the ceiling to plug them into. My garage is still in progress. Open ceiling, just metal on the walls and gravel floor. Concrete will be poured in a few weeks hopefully. Calling for a couple of feet of snow though starting Friday.
I had a 4 foot fixture with 4 t8 32w 6500k bulbs and these lights are brighter
kingchevy
Those look like really nice fixtures, especially for the money. I need 32 4 foot fixtures for my 30x50 with 12 foot ceilings but I want to daisy chain 3 rows of 9. From what I can see they don't look like they are designed for that. Maybe I could buy one and see if I can drill the ends and connect them with *******.
drmarkr
Tucson
I have the Costco version. ...daisy chain would be simple.
92GreenYJ
San Diego, CA
Yep. I went way overkill with my install though. 2 car garage I ran three rows of 4 front to back and another three across the back wall of the garage. I almost need sunglasses when I go in there.
Forever Fixin
MN
Using two of them in a 30x40x14 over high use areas. Bought 3 more that I'm hanging onto and they will be replacing the 4' florescent lights as ballasts start to go. Very impressed, Instant, bright light, even when the shop is cold. They are designed to hang from chains, but I flush mounted my by drilling and attaching with screws. Don't get too close to the ends if you go this route, that's where all the electronics hang out........ask me how I know.
Wardster
Kingston, Ohio
I bought two of them and installed them in my loft. I installed a switched outlet and plugged them both into it. I have only had them for a few weeks, but so far so good.
Todd.Brock
Cincinnati
I got two of them at Christmas. They are pretty awesome in a basement. They don't come with pull chain extenders, ( mine didn't) so don't mount them too high!
SierraDenizen
Nor Cal/Nor Nevada
Ah, thanks! Nope I wouldn't know about messing up with live circuits :)
elknturkey
Ignore the mess. 3 rows of 3 lights
1 row
2 rows
3 rows
3 rows plus 2 over the work benches
NorthNjWK
Northern NJ
I have 2 of these lights and they are great! I will be getting 2 more shortly for the garage and a few for the basement.
Kaervak
Cleveland, OH
I have three in my 2.5 car garage. They are incredibly bright, such a great upgrade over the T12 fluorescent fixtures I had in there before. Apparently my Sam's Club has a slightly different version that what it listed on the website. The ones I have are 4500 lumens not 4200 lumens and 240 LEDs total not 120. I keep forgetting to check the model number on the boxes to see if they're the same as what they have on the site.
98ramtough
I have a 30x60' shop and just finished installing the 4' LED lights from costco. I previously had 150w single socket flood type lights and they were terrible. For my space I had 12 and just used the $1.88 plug to socket converters and hung the lights. I still have a few left to add, but very happy and should cut the power bill some.
Falcon67
Merkel, TX
I bought two to put in the race trailer but they flickered more than the T8 units when on the generator. So i havent decided what to do with them yet. They also dont lend themselves to surface mounting well. Light us good, about the same as T8 6500K.
addodge
I am having a 40x40 garage built with 16 foot sidewalls. The peak is 20ft tall in the center.
I was going to go with a basic T8 in 8ft lengths, but for the price I can get 24 of these. I am thinking of installing them in pairs similar to how a 8ft T8 would look and doing 3 rows of 8 lights. If they were hanging in the 16 to 18ft range, would that provide a good enough amount of light to enjoy working in the garage?
Autorotica
SE Pa
Is anyone else using these lights? Any updates on how they are working?
I have 30 of them in a 60x64 building with scissors trusses that are about 19" tall at peak. I have the lights hung to about 14' height. Have had them for better than a year at this point. Very happy with them and I have dark everything from the roofing foam on the ceiling and walls.
30 fixtures x 3800 lumens = 114K Lumens.
114,000 Lumens / 3840 square feet = 29.69 lumens per square ft.
3800 Lumens x 24 fixtures would be 91,200 lumens
91,200/ 1600 square ft = 57 lumens per square ft.
I am sure you would be happy with that amount of light. I did 5 rows of 6 fixtures.
Chris
addodge
Thanks Chris,
That was exactly what I was looking for.
I came up with 67.5 lumens per sq ft so I was worried that it wouldn't be enough. (4500*24/1600)
I saw several people that said they recommended around 80.
I will have the vinyl backed insulation that is white on both the walls and ceiling so that should work out nicely.
Thanks for the reply!
Andy
My Old Tools
Hamrick Lake, TX
I have 16 of the Costco ones in a 30x40. Half of the space is 10' ceiling, half is vaulted up to 22'. I have 8 in the tall side at 14' and 20'. 6 are in the 10' side flush mounted. 2 are in the loft. All on one 15 amp circuit switched. They've been up awhile with no failures. Good light, good color values, I'm happy. $25.99 at Costco now.
Pointbock
AK
Anyone know the temp/color and CRI of either the Sam's or Costco lights?
Autorotica
SE Pa
Thanks Chris,
Andy
Oops... Sorry Andy. I have the Costco lights and used those numbers for the math which is why I was low on the lumens.
The Costco lights are 4100K. Generally speaking, I prefer the lower value numbers. 6K looks really blue and dim to me. I havent seen the Sams club fixtures in anyone's space as of yet to have an opinion on them.
Chris
kingchevy
I picked up 10 of the Sams LED's to start with. They are very nice for the price. I took one apart to see if there is a way to gang them end to end and there is not. One of the plastic endcaps comes off to reveal a chaseway in the the aluminum extrusion, but the other endcap that the cord goes into contains the pullchain switch and it fills up the chaseway with a circuit board. So Maybe the next best thing is to mount 2 with the cords together and have 1 jbox for each 2 lights. I also see that they are out of stock online, is that a sign that they won't be in stores for long?
jives
Central NY
I was just at Sam's Club (first time ever). They had both LofA LED shop lights and Honeywell. The Honeywell's were a dollar cheaper ($35) and were the one's on display. It looks like those will replace the LofA fixtures.
