I'm needing an air compressor, something will deliver at least 10-11 CFM @ 90 psi.
I will be doing basic sandblasting of small parts, nothing large scale, nothing on a daily or weekly basis, just as the need arises to clean up surface rust or maybe bead blast something before plating it.
I don't have a lot of room to work with, floor/permanent mount isn't an option as I will need this to be portable.
I prefer electric, and can add a breaker to the shop (single phase power) if necessary.
I much prefer a 'real' compressor over the light duty, oil less or pancake types. Something that has parts (reasonably) available from a standard compressor shop if repair is needed.
I'm hoping someone here can recommend a unit with a ~15-20 lb tank on wheels that can churn out enough steady cfm to handle pushing a small sand blaster.
What are you guys using ? Any you can recommend ?
