Sanding before second coat ?
technomad70
I put on one coat of epoxy with flakes and found some areas that did not have as much epoxy as others. In order to put on a second coat, I tried to sand the first coat using a pole sander with 80 grit sand paper and also tried a Medium sanding screen.
All this appeared to do was to take off the flakes, and the epoxy is still shiny. I am thinking of renting a Floor Maintainer from HD and using it with a 80 grit sand paper. Anyone see a problem with this ? Will it take out too much of the first coat ? Any other options ?
http://www.clarkeus.com/products/polishersandburnishers/fmmodel.aspx
rugerlady
How large is the area? would a hand sander do the job? Usually all you need to do is take the shine off the floor.
