Sawmill
R
RivennHewn
PNW
Is magnolia a desirable wood for milling? Tons of it around me.
It can be, if you have some that’s big enough.
Nice colors and interesting grain.
Turns on the lathe nicely too.
(Image ripped from the interwebs)
R
RivennHewn
PNW
The wood is the dreaded cottonwood, a close relative to Poplar.
The off-putting smell goes away when it’s dry.
I cut this up to build the loading door of the kiln because it’s so much lighter than Douglass Fir.
The frame of the door will be the cottonwood with 3/8” plywood on either side. The “stud bays” will be filled with 2” ridgid insulation.
The outside of the door will have the same Cedar siding as the exterior side of the wall.
Remember to allow for season expansion when you build that.
RickP
Annapolis, MD
I'm not sure if I've ever seen cottonwood before. Hope the heat doesn't make the smell come back...
I didn't realize it was closely related to poplar -- I use that a lot because it's so lightweight (and it grows like a weed here).
That insulation should be just about right for the kiln door.
R
RivennHewn
PNW
It took dragging out a bunch of tools, but I got the loading door built. Forgot to take pics of the inside.
I’m now thinking I’m not going to hang it on hinges. It’s going to be a removable panel.
It’ll only need to be removed when I’m loading/unloading. I can grab it and set it aside, and not fight a door flopping around in the wind.
I’ll set it in place, and pac the gap with backer rod. ✅
Toolfool
Columbus, Ohio
GAP !?!! What is this "GAP" you speak of ? Wasn't this custom made ? :headscrat
R
RivennHewn
PNW
Once I install the threshold, it’ll be a friction fit.
Any tighter would just be a pain to remove it😜
I did find a magic bullet for the remaining smell.
Smells great in there now. The wife is sitting in there today, reading a book. It’s 40 degrees outside, and a comfortable 77 (and climbing) inside.
Treeman
Not to nitpick.......ok, lets nitpick, LOL. Be careful of the nomenclature. There is tulip poplar (yellow poplar) that is in the Magnolia family. Tulip poplar is somewhat hard and is used in cabinet making. And there is the willow family that contains lots of species under the populus genus: cottonwood, aspens, balsam poplar (bam) - these are quite soft, high moisture, and yes very stinky (paper mills). In the lake states it is not uncommon for loggers to lump these together and call them poplar or popples.
R
RivennHewn
PNW
Treeman,
Always appreciative of info. Feel free correct me anytime.
We have cottonwood and poplar here, but I misstated the Tulip part, as they are a more Southern tree.
There is one Tulip Poplar here in Skagit Valley, that may well be the oldest living thing in the greater Skagit area (Mount Vernon, Wa.) Brought here by a pioneer of the area.
Younger, but bigger than one planted by George Washington in Mount Vernon, Virginia.
R
RivennHewn
PNW
This is a “shouldn’t you be a work “ post.
I couldn’t quite make it there today. Needed a play with my toys day, as the weekend was too short.
The “bunch” of trees growing together that I pulled from the channel last week had two similar sized and shaped trunks growing out of the same rootball.
I cut them up, with thoughts that they make a nice pair of table legs. If they all stay intact.
Moisture content is pushing 90%😬.
I painted the end cuts, and stocked them outside, undercover. I’ll let them air dry awhile before they bake in the kiln.
Treeman
Treeman,
My intent was more to introduce people to the idea that regional dialect can sometimes be confusing regarding local tree names. It's tough to "correct" a person of your hands-on experience and in-depth knowledge based on real life work. What you are doing is astounding and I love your results. It's what happens when a person has passion.
R
RivennHewn
PNW
Thanks.
I’m not sure if it’s passion, compulsion, or just a dopamine hit, but I love the revealing of that which is in these ugly logs I find.
Kinda like fishing, ya never really know what your going to find.
Today’s catch was Alder.
Jayman17
Seattle, Wa
Riv, are all these cut up slabs eating up all the floor space in your shop? You must have a pretty big pile by now. Hope you have a great Thanksgiving holiday!
Jay
R
RivennHewn
PNW
Jay
The pile is growing!
Hoping to have some projects to post on my Table thread sometime soon.
Happy Thanksgiving to you too!
R
RivennHewn
PNW
Temp’d in the cheap little digital thermometer/hygrometer units into a sealed box.
I’ll redo it latter when my siding goes on.
Not sure this is the greatest thing ever, but it’ll do for now.
At least I’ll be able to see the difference in relative humidity/temperature, even if they aren’t the most accurate.
R
RivennHewn
PNW
I seem to be obsessed with monitoring the kiln temps😐.
Had an hour before the bird is done, and the wife asked me to leave the kitchen.(nicely)
Gave me a chance to seal up the end grain on the log pile, and stack the little maple(?) logs on the sawbuck. I want them off the ground .
Hope y’all have a great day!
R
RivennHewn
PNW
A little online shopping yielded a nice accessory for the kiln.
A NOCO thru-wall extension cord port.
With this, I can run power into the kiln w/o having it go thru a door. Just drill a 2” hole and mount it to the exterior wall with the pigtail splitter inside. Air and water tight.
R
RivennHewn
PNW
First attempt at quarter sawing a log.
Didn’t quite nail the setup, but really close.
Started with a small diameter Douglass Fir to learn on.
They’ll make nice trim boards for some future project.
R
RivennHewn
PNW
Woke up to a channel full of logs.
Pulled 3 today.
R
RivennHewn
PNW
Froze my fingers off, but made a little progress on the kiln loading door.
Lots of Vycor, and got an aluminum threshold cut and installed. Ran out of tyvek, so I wrapped the door with FSK for now.
I cut a little cardboard heat shield/cover for the temperature probe to keep it out of the direct sun.
R
RivennHewn
PNW
The channel gods left me another mess on the ramp. Just another winter high tide with North wind blowing logs and seaweed right up the ramp.
Took me a couple hours to send it all back where it came from.
R
RivennHewn
PNW
Slack water between tides, floating 50’ from the ramp.
About as easy as it gets!
R
RivennHewn
PNW
Decided to go back for yesterday’s log’s stump.
Hard cranking, but got the ol Ford to start. Got to use the bed crane for its intended purpose👍.
It’ll be interesting to see what’s inside!
R
RivennHewn
PNW
Pulled in a 45 footer today, gave it to my neighbor to fill up his firewood shed.
I know what he’ll be burning next Christmas.
R
RivennHewn
PNW
Started off my morning at 6:30, in the dark.
Kayaked down the channel to help a neighbor who had a large log caught up in his pier. The tidal force on a log that size could do some damage.
I secured it, and went to work. Came home early.
Kayaked back down to the pier with my chainsaw and peavey. Cut the log into thirds, and brought the best part home. The rest was junky, and floated away.
One the way home, I spotted another likely log on the other side. Drug it home as it got dark.
Nice way to start and end my day.
larry4406
Northern Virginia
These random floating logs - are they logs from present time logging or ghost logs from the long ago past that have somehow surfaced/become unstuck and found you?
R
RivennHewn
PNW
Larry,
I wish I knew.
I think the majority of them come from upriver, due to high water rain events or land clearing.
They come down river into the salt water and the prevailing currents bring them past my door.
Along the way, the get stripped of leaves, branches, and bark.
