PugetDude
When I lived on the Sound I swear you could walk across the bay in front of our house on July 1 by hopping on the crab pot bouys.
Worst opening day ever.CRAB !!!
That’s the only crabs he’s familiar withDon’t go bringing your California issues to Arizona, Cam.
Jump on it!Goal accomplished.
How do you guys stress test your tack welds?
I did!Jump on it!
That would have hurt, a LOT, if the weld broke.Goal accomplished.
And that’s just tackedThat would have hurt, a LOT, if the weld broke.
Good on you for having self confidence!
And that’s just tacked![]()
I’m right there with ya.Whenever I want a tack to come off it involves a grinder.
When I want it to stay put if I look at it sideways it falls off.
Not sure if my degrading welding skills are from lack of practice or from failing eyes. I can't tell you the last real project I welded, and I'm on year 3 of this tank, but I also haven't seen an optometrist in years.
I used to go through 2 tanks a year.
Thanks!Try eBay for a replacement gun- probably cheaper and easier than chasing parts. Don't know what model welder you have but there are a lot of options:
8Ft Mig GunFit Craftsman Flux Core 135 Gasless Wire Feed Welder MODEL 51264 | eBay
Find many great new & used options and get the best deals for 8Ft Mig GunFit Craftsman Flux Core 135 Gasless Wire Feed Welder MODEL 51264 at the best online prices at eBay! Free shipping for many products!www.ebay.com
Love it!How are you liking the Milwaukee metal saw, Riv.?
Agree completely on the wrong-sided blade design- Not sure why anyone would want to try to peer over the bladeguard, motor, and handle to try to see the cutline.Love it!
Would love it more if the blade was on the correct side of the saw![]()
I always use a guide clamped to the workpiece.Agree completely on the wrong-sided blade design- Not sure why anyone would want to try to peer over the bladeguard, motor, and handle to try to see the cutline.
The channel.Where did you find those pecker poles, Riv?
Just stretch out a few blue tarps, surround them with pallets, pull in a derelict motor home and the authorities will let you have all the "campfires" you want.Ripped into another ugly stik.
Lot of waste, and not much to show for the effort.
I’m going to roll the other section of this log back into the channel
There’s a burn ban currently, but it excludes camp fires.
I’m cleaning the site, but calling it camping.
Especially when you consider that I look pretty “homeless “ most of the timeJust
At least the right hand piece looks usableToo bad it has some significant internal tension/stress.
Got to take the good with the bad![]()
It’s all useable. Just need to pick a project that fits the scale of the material.At least the right hand piece looks usable
Top is about 4.5”. Bottom about 6+.That would make a great bottom section of pipe flagpole.
What's the ID at the top of the taper?
I was thinking using the hex section as the base, then transitioning to a 10' piece of pipe, then a second section of slightly smaller diameter.Top is about 4.5”. Bottom about 6+.
I’m considering replacing this post at my entry, when I take the ugly fake rock off the house.
The existing base is too big, and is in the traffic pattern to the front door.
The pole does have a flag pole bracket on it.
I found a spec sheet for a new one. The 30’ model is 255lbs. Doesn’t say wall thickness.
I have an email into them for more specifics, and $$.
I built my dad one just like that probably 15 years ago. Don’t think he’s had to change the rope out yet.I was thinking using the hex section as the base, then transitioning to a 10' piece of pipe, then a second section of slightly smaller diameter.
When I lived on the Sound I had a 25' welded steel flagpole. it was 3" S40 on the base, then 2.5", then 2" on the top section. It looked like they slipped each section about 2" or so inside the other, with a fillet weld on top of the larger section. The entire pole was hinged at the base and locked in place with 2 bolts. Square sheet metal cover over the hinge assembly You could tilt/lower the pole to the ground if you ever had to re-thread the top pulley or re-paint the pole. Luckily I never had to try it out.
Making some shade, to stop the sun from F’n with my welding helmet.
Goal today is get all the joints prepped, line the ribs up straight and true. Then get everything tacked together.
We’ll see how that goes.
