AntonyJ1214
This is the compressor that was in my house when I bought it a couple months ago...
I had to get some work done to it because the pressure switch was leaking and I wanted to get it all cleaned up... so I took off the pressure switch (which I believe is a Square D pressure switch but not positive) and I noticed that it has another switch on the side of it that has a line running from the motor to the after cooler. Is that the overload switch? I took it off and cleaned it out because it was all gunked up with oil and crud. When I finished cleaning it and giving it a small make over I put it back together without the switch. Here it is without the pressure switch installed and wired up.
You can see that the line goes strait from the motor to the after cooler. Is that 2nd switch necessary or can I leave it off?
