JJOrzech
Anyone on here sell parts for Saylor Beall Air Compressors? I am looking for the following parts:
- belt guard
- magnetic starter
- pressure switch (178 psi)
- I intend on running a 5HP Single Phase 1725 RPM motor which means I'll need an 8.2" pulley (if my math is right) as original motor was a 1750 RPM. Will also need a belt for the smaller pulley.
- I need the valve access tool
- the tool used to press motor away from pump to tighten belt.
- I also would like a gallon of the correct Saylor Beall paint
- replacement labels.
I also need a wiring diagram to figure out how to wire the low oil cutoff and pressure switch and motor.
Lastly, Can anyone tell me what the copper line running from bottom of tank to top of tank is for? I assumed the bottom of tank is where the drain should be.
- belt guard
- magnetic starter
